Suffering from a severe case of Whiplash as result of Doug's car!
Originally Posted by shiv@vishnu
If you got Fidanza cam gears which were designed for an EVO, you want to retard them just 5 degrees, not 12.5. Same with ours gears.
The only differences with our gears is that you align the gears themself to the cam cover marks with the red dot, not the zero mark.
Shiv
Shiv
George
Shiv
Shiv
vishnu cam gears. I was really trying to figure out why they kept telling me they you must retard them 12.5 degrees. Just didn't sound right to me. Thanx for clearing it up.
Originally Posted by Boost Solutions
Thanks for confirming all that for us, Shiv!
George
George
Shiv
George-- It also depends on which dowel hole you use with the Fidanza gears. There are two options: one for the EVO and one for the DSM. If you installed it on the DSM hole, you will need to offset the install by 1 tooth and then retard the adjustments 5 degrees. If you install it on the EVO hole, all you need to do is retard it 5 degrees.
Shiv
Shiv
Shiv
Shiv
George
Originally Posted by snoop
261.8 (on DD) *1.18= 309WHP on the Dynojet.
. Hey maybe one day soon my car will give you whiplash too
...... Meantime, remember about those wheels I told you about?https://www.evolutionm.net/forums/sh...66#post1054366
Originally Posted by BadazzCR
no problem man just don't sue me for the whiplash.
glad everyone last night enjoyed the rides and hope to see yall at commerce friday.
Cool, I just tried aligning Tomei, HKS, and stock cam gear, and all the dowel pins and the timing marks lined up perfectly.
George
George
I really enjoyed reading this post and riding in Doug's car and seeing everyone(Shiv, George, David and even Noize) getting along and helping others with problems instead of the usual bashing.
