cheapie mud guards from Canadian Tire
Old Apr 28, 2009 | 07:17 AM
GTE28's Avatar
Saw the Lancer OEM rear mud guards...wow $85 for just the rear
I went to Canadian Tire and bought the cheapie $15 mud guards ( a bit thinner then the Lancer ones) and they're not too bad looking, and they do the job of stoping debris from being kicked up.
Got the idea from someone in the EVOX forum.
I prefer the more subtle look over the Rally Armour ones (as much as I use to follow WRC, I'm not a big fan of the large mud guard look for my DD). The price of the Rally Armour ones are a bit outrageous for what
it is...a piece of rubber! Only issue is that the OEM guards come with plastic fasteners that are longer to fit the added thickness of the guards. I ended up using a zip tie cause the old fasteners
are too short (still trying to source similar ones, so far no luck with Cantire, Part Source, Carquest). For $15 they actually look pretty good as they flow with the rear bumper curve, much more
subtle. Will try and post a good side picture.
Old Apr 29, 2009 | 05:26 PM
stitchflip's Avatar
so you got them for all 4 wheels or only for the rear? and how did you use the zip ties? DIY! lol
Old May 1, 2009 | 10:04 PM
GTE28's Avatar
Its $15 for just the pair (same from Canadian Tire or Walmart), supposedly the same ones for front and rear, but on the front there is a gap created because of the way the wheel well plastic is shaped. I haven't had a chance to tackle that yet.
The fit on the rear is nice and flush.
Where the rear guards are mounted, there is already 2 plastic fasteners, the 2-piece type where you push the plug piece though and then you push another piece through the center that expands the prongs. The fasteners are securing your rear bumper to the inner wheel well plastic piece, via two square holes. The reason I had to use a zip tie is because the fasteners are too short to go through the mud guard and then both the bumper and wheel well plastic. I can't find any similar fasteners anywhere...Candian tire/Parts Source/Car Quest/dealer...none. The OEM guards come with longer fasteners but they can't be order through the dealer. Will try the internet.
The only other difficult part is to get the hole locations on the mud guards. What I did was dab a drop of liquid paper onto the 2 fasteners heads, then quickly placed the guards over them , leaving a white mark on the back side of the guard to drill 2 holes. I found the best way to position the guards was to push the side of the guards against the bumper (guards flex quite a bit), then raise the guards up, then move the guards in a rearward direction over the plastic fasteners. This way the liquid paper didn't smudge onto the guards, and just left a nice white dot. The trick is to repeat this procedure on the other side and to get the same position. I've gotta loosen one of the zip ties and reposition the guards a bit to match the other side. Not a big deal.
The zip tie is a bit ghetto style but its the easiest solution till I can locate some similar fasteners.
These cheapie guards actually extend lower then the OEM ones.
Old Oct 31, 2010 | 07:03 PM
jdc's Avatar
jdc
could you post a pic of the front guards installed?
Old Nov 6, 2010 | 11:25 PM
gabaujla's Avatar
Doesn't look too shabby. Good find, i'll probably have to pick a pair of these up.
ToLate24
Dec 13, 2016 11:22 AM
fafaforza
For Sale - Cars For Sale
Nov 15, 2016 07:14 AM
Howulikemyevo
Apr 2, 2016 06:31 AM
teeRad
04-06 Lancer / Ralliart Show / Shine
Feb 13, 2015 07:08 AM
WRX1832
Dec 10, 2004 11:31 AM
