Cobb AP PSI
Old Mar 11, 2011 | 08:23 AM
Jookies's Avatar
Cobb AP PSI
So I installe dmy Cobb AP today ( yayyy) with the stage 1 map (cobb sf intake) and the map states that boost shoul dbe ~24 +/- .8. I did 2 WOT pulls to test it, and the pulls had 26.6 and 27 PSI as the peak it hit, is this a dangerous amount of overboosting?
Old Mar 11, 2011 | 08:58 AM
Golden's Avatar
Flash the LWG version of your map.
Old Mar 11, 2011 | 08:59 AM
Jookies's Avatar
KK thanks!
Old Mar 11, 2011 | 10:23 AM
Jookies's Avatar
So i did the reflash with the LWG, and 2 WOT pulls hit 23.5 and 22.6 (falling right around the lower end of the 24 +/- .8). I want the 27 back! lol, but i guess it's better to be safe.
Old Mar 11, 2011 | 11:23 AM
Kracka's Avatar
Definitely better to be safe You could always open both maps and do an average of the two and try that.
Old Mar 11, 2011 | 01:23 PM
The_Evo_DK's Avatar
I need the connector for my cobb ap, i just have the unit and not sure what the previous owner has done or with what maps
Old Mar 12, 2011 | 07:33 AM
nismo1118's Avatar
I think I am getting the same thing I will have to try the LWG flash
Old Mar 14, 2011 | 06:05 AM
Jookies's Avatar
Did you try the LWG yet?
Old Dec 4, 2011 | 06:33 PM
SmokeSolid's Avatar
Im safely hitting 27 psi on stage one with just UICP AMS.
Next tuesday I will be installing the AMS downpipe and test pipe and run stage 2.
Old Dec 5, 2011 | 07:29 AM
Jookies's Avatar
Wide mouth or regular?
Old Dec 5, 2011 | 06:40 PM
lil ayzian's Avatar
how much is the cobb tune?
Old Dec 6, 2011 | 03:52 PM
Sidnakit's Avatar
^go to cobb tuning and itll say.. its like 600 bucks
Old Dec 7, 2011 | 09:14 AM
Kracka's Avatar
Nope...$400 is the regular price for a Cobb protune on the dyno.
Old Dec 8, 2011 | 03:20 PM
DocBoz's Avatar
w/ cobb stage 1 aem intake 91 my logs show 25.5 psi as well as peak boostnot sure i should be too concerned tho no sign of knock but maybe i should try the overboost map as well but then again i now have the dp, cp and catback i need to install so ill be going to the stage 2 map anyway, wonder if ill still have an overboost condition...
Old Jan 18, 2012 | 02:18 PM
metagalaxxy22's Avatar
i have the cobb stage 2 ap for my ix..i have tbe and injen cai, i am on stage 2 flash v 101 91 oct ca...
i belive that since i got the car the throttle shaft seals are leaking.
it has always gone to 20-21psi...but now im lucky to hit 20psi..sometimes i only peak at 13 psi..
what do you guys think i will be hitting if i fix the leak..??
i have a mbc... but i think since its flashed at 91 oct i think maybe 22psi would be the norm??
suggesstions?
sorry for the dumb question
