2011 GSR stage 2 21 boost...
Old Mar 10, 2012 | 10:55 AM
kazshell's Avatar
So, I have a 2011 GSR with the 2011 stage 2 beta map. I also have a Test pipe and a cat back and a K&N drop in but I dont seem to be breaking 21 boost. I talked to Cobb Austin and explained all my mods and they said I could run stage 2 with the test pipe. I still have the boost pill in though should I take it out? I have the logs for the WOT pull in 3rd I have 3 instances of knock. Anyway here are the logs. How do these look?
File Type: zip
File Type: zip
Old Mar 13, 2012 | 08:06 AM
kazshell's Avatar
any ideas? maybe I should send these directly to cobb..help out with their 2011 testing..
Old Mar 13, 2012 | 07:07 PM
erikm-x's Avatar
boost leak maybe?
Old Apr 13, 2012 | 09:55 AM
cbr1000's Avatar
curious to know what you ended up finding as the problem or did you pull the pill?
Old Apr 23, 2012 | 07:55 AM
kazshell's Avatar
I haven't pulled the pill yet, I did some more monitoring with the AP and I saw it peak a couple times at 24 - 26 but only a few times. I am going to pull the pill here in the next couple days and re-log, I meant to do it sooner but I have been busy getting my bike ready for summer.
Old Apr 27, 2012 | 12:37 AM
GTS-SB's Avatar
Any luck? Im having the same prob
Old Apr 27, 2012 | 03:06 AM
MisterHappy's Avatar
If you are underboosting, try pulling the boost pill, might solve the problems. On stage 2 ill hit 26lbs consistently in 4th on a hard pull other then that i stay between 21-24lbs.
spomi
Cobb AccessPORT
Oct 8, 2016 05:30 PM
milab21
Jul 28, 2014 07:29 AM
2012_Evo_X_GSR
Cobb AccessPORT
Mar 22, 2014 01:21 AM
SeanM505
Cobb AccessPORT
17
Apr 8, 2013 08:22 AM
hoobastnk90
Cobb AccessPORT
Nov 21, 2012 08:48 PM
