How is 93 oct with 10% ethonal?
Old Apr 4, 2012 | 09:43 AM
zsak's Avatar
I am wondering if it is safe to use the 93 oct tunes if the gas had 10% ethonal? Or should I stick with the 91 tunes. Thanks for the help.
Old Apr 4, 2012 | 09:47 AM
Kracka's Avatar
93-octane tunes are all designed for 10% ethanol, this is standard throughout the industry unless stated otherwise.
Old Apr 4, 2012 | 10:37 AM
AWDTerror's Avatar
A lot of stations, at least here in Missouri will advertise that they are ethanol free.
Old Apr 4, 2012 | 01:18 PM
Kracka's Avatar
FYI: It's technically illegal to use that in a modern street car. Obviously it won't be enforced, but there's a little factoid for you. You'll actually find you make less power than E10 93-octane too; although gasoline contains more energy per gallon, the 10% ethanol works well as a knock-quench.
Old Apr 4, 2012 | 01:50 PM
zsak's Avatar
thanks for the help guys, well I tried the 93 tune and logged it and man did I get some knock in the higher rpms. highest was 2.46 at 6023 with 23psi and leveled off to 1.76 at 7500 13psi. I may change it back to 91 oct. Does that seem high to you guys? Everything before 6000 rpm was 0 knock.
Old Apr 4, 2012 | 02:04 PM
mirkendargen's Avatar
Semi-offtopic, but I've been wondering if anyone's ever tuned on E20 to see how it compares in knock resistance 91 or 93. It would obviously be far better mileage than E85, I just don't know how to predict the knock resistance since you don't know the octane of that 80% gas. I would assume it's just 87 for cost, but is 20% alcohol enough to make it better than 91 or even 93?
Old Apr 4, 2012 | 02:07 PM
zsak's Avatar
on a side note when I ran this 93 oct with the 91 tune I did avg 20 mpg with mixed driving.
Old Apr 13, 2012 | 09:59 AM
cbr1000's Avatar
I was reading something the other day about a push to switch nationwide from e10 to e15
Apexsilver03
Sep 18, 2016 09:31 AM
Boosted Tuning
Apr 25, 2016 09:36 AM
EvoNo0b
Apr 20, 2015 10:11 AM
mitevox
Cobb AccessPORT
Aug 25, 2014 06:44 AM
