Cobb AP OTS Tune reliability concern
Old Apr 11, 2012 | 09:09 PM
3000GT-GTO's Avatar
Guys I 've read many post about cobb ap stage 1 ots map knocks,
So my question is doesnt that blown your engine after a while?
And yet i hear people say its safe to use ots map all the time.
Are they just ignoring the knock and dont know the consequences?
Old Apr 12, 2012 | 07:32 AM
Jookies's Avatar
Kind of a vague question there... Is it consistent knock? Or phantom knock? Is it under WOT, or during shifts?
How many counts are you getting?
Also, the stock tune knocks very often (4-5 counts sometimes) your cars Ecu will start pulling timing at 3 counts.
Old Apr 12, 2012 | 11:19 AM
3000GT-GTO's Avatar
so what your saying is ECU will pull timing automatically and the car will be reliable afterwards?
I am talking strictly stage 1 maps on the Cobb AP, does the ECU automatically corrects itself? Because I am under the impression you just Flash and drive,
I dont have a AP yet but i am researching the issues first before I buy.
Old Apr 12, 2012 | 12:41 PM
S2K2EVO's Avatar
As long as nothing is already wrong with the car the AP used correctly should be very safe and reliable. Now if you have the wrong intake for the selected map or the wrong set up for the map you may run into problems. The car runs so much better with the SF intake and inlet on stage 1 than it did when I was running the ETS on the stage one SF map.
Old Apr 12, 2012 | 12:48 PM
Kracka's Avatar
Log a stock car, they knock quite a bit more than any stage 1 OTS map. Use quality gas and you'll have nothing to worry about.
Old Apr 12, 2012 | 02:01 PM
3000GT-GTO's Avatar
Wow thats interesting to know that stock cars knock more the stage 1, I will defintaly keep that in mind and do a log before the flash.
Old Apr 17, 2012 | 07:36 AM
I NEED BOOST's Avatar
i too am getting knock counts of 4-5 towards redline on the stock map/stock car. i wanna assume the only solution would be get a protune?
Old Apr 17, 2012 | 07:46 AM
scarryy's Avatar
I ran the Stg 1 OTS map for ~50,000 miles problem free. Then at 60000, did bolt ons and protune. 22,000 miles later all is well.
Bottom line: Your results may vary, but Cobb OTS maps are safe when applied to the correct setup.
Old Apr 17, 2012 | 09:14 AM
Kracka's Avatar
boyvang
Oct 6, 2015 05:56 AM
evofan_08
May 12, 2013 12:08 PM
MisterHappy
Cobb AccessPORT
May 8, 2012 11:11 AM
valin
Cobb AccessPORT
Nov 14, 2011 08:03 AM
Logitech80
Dec 14, 2010 03:09 PM
