Bad knock or Normal....
Old May 1, 2012 | 05:15 PM
EXcel4600c's Avatar
Currently running stage 2 ACN91 v108 on a 2010 MR touring:
Mods:
Perrin panel filter
ETS HFC pipe
Perrin Catback
Im getting some pretty good knock and wanted to have someone take a look at the logs.
Ive been told some things and i wanted to get the experts or someone that knows more than i do.
Regular Stage 2 was knocking worse so i flashed the ACN map to see if that made a difference and had a full tank base gas station.
Thank in advance.
File Type: zip
Old May 1, 2012 | 07:31 PM
dldjros69's Avatar
piggy
^To piggy back on that - what is normal knock and not normal? Also what does acn stand for?
Old May 1, 2012 | 08:02 PM
EXcel4600c's Avatar
i tried to post the Data-logs but it wont accept .csv files
Originally Posted by dldjros69
^To piggy back on that - what is normal knock and not normal? *Also what does acn stand for?
to answer your question ACN is the title to one of Cobbs maps 91 octane fuel from Arizona, California, or Nevada
Ok there its loaded as a zip. There are two data-logs same day within a few minutes of each other.
Old Jun 3, 2012 | 07:26 PM
dozer808's Avatar
How much knock are you getting? #'s
Old Jun 3, 2012 | 08:43 PM
4B11AWD's Avatar
Its a little harder to tell true knock on the SSTs.
The first datalog looks ok and you can tell that its correcting itself by pulling timing and reducing the knock count.
The second datalog looks weird though in the higher rpms where you're getting 6 and 7 counts continuously. Was the road bumpy? Anything that would have caused extra noise or vibration?
spomi
Cobb AccessPORT
Oct 8, 2016 05:30 PM
evodan94
Cobb AccessPORT
Sep 19, 2016 12:43 PM
si00dcracer
Cobb AccessPORT
Oct 6, 2015 04:46 PM
haxr303
Sep 2, 2015 11:16 AM
nqramjets
Cobb AccessPORT
11
Jan 3, 2014 04:37 PM
