'11 MR Stage 1 + SF intake - 1 bad pull (v403 ACN91)
Old Dec 11, 2013 | 02:02 PM
nqramjets's Avatar
Unhappy '11 MR Stage 1 + SF intake - 1 bad pull (v403 ACN91)
Hi all,
First post on this forum; if I'm missing anything please let me know, and thanks ahead of time!
I'm running the v403 map for my 2011 MR from the post at near the top of this forum. I was running v401 previously and was suffering from the idle drop upon releasing the brake from a complete stop. For me this has disappeared with v403 maps.
After installing the v403 maps I logged a bit to get some data for reference.
I've looked at the data but don't know what to look for specifically besides max boost in a column, and knock count.
The first 3 logs seemed fine, and the car felt fine. For the last pull I was in 6th at a low RPM and went WOT to get a nice slow pull. Right around 3500 it knocked like crazy and the service engine light flickered, so I lifted immediately.
Reviewing the last log I see a string of 15ish cells with a knock count of more than 10 per cell, 19 being the worst.
The other pulls in lower gears felt really good and have minimal knock so I don't know exactly what happened.
If someone with more experience could take a look at the logs that would be very helpful. I want to send the logs in to COBB (though I'm not sure to who) as well, but they'll be gone for the holidays soon, and if this map is dangerous for the car I'd rather know now.
The car:
2011 MR
COBB AP v403 ACN91 map
COBB SF Intake
Thanks ahead of time,
Ryan
File Type: zip
Old Dec 11, 2013 | 05:02 PM
OkcSupra's Avatar
you need to do a 4th gear pull around 3k rpm to put the correct load on the engine.
Old Dec 12, 2013 | 01:42 PM
antyoo's Avatar
Is the stage 1 map set up to run the Cobb sf intake?
And yea, 6th gear is not a good gear for logging
Do 4th as mentioned above. On my gsr I log from 2000 to 7300.
Old Dec 12, 2013 | 02:12 PM
3000GT-GTO's Avatar
You are using the wrong gear my friend, hopefully you didn't damage your engine rod.
Old Dec 12, 2013 | 02:18 PM
Ev0ikon's Avatar
Originally Posted by nqramjets
. For the last pull I was in 6th at a low RPM and went WOT to get a ...
how to bend rods!
Old Dec 12, 2013 | 09:13 PM
deanob's Avatar
Still doesnt change the fact he's getting high knock counts in 6th. He should be able to go WOT in any gear.
Old Dec 14, 2013 | 07:48 AM
3000GT-GTO's Avatar
Not saying you cant wot at 6th gear, just not at 2000RPM because it will cause too much stress and bend a rod. You can go wot at 4000RPM 6th gear it's fine but just not less than 4000RPM, you can imagine using your thumb to support 10 LBS of weight than tried using your pinky to support 10 lbs of weight concept is the same.
Old Dec 16, 2013 | 08:05 AM
COBB Tuning's Avatar
I took a look at your logs and they all look fine aside from the last log with the high knock counts. As others have said, it is typically not recommended to go wide open throttle in a high gear at very low RPM due to the tremendous load it puts on the engine. That in conjunction to running a SF Intake on a map not calibrated for it is a recipe for detonation. If the car is currently running normal then you should be okay, but PM me your email address and I can get you a map that is correctly tuned for the intake you are running.
-Eric
Old Dec 17, 2013 | 02:33 PM
ikt's Avatar
ikt
-Eric
what's up with removing the ability to log AFR?
Old Dec 18, 2013 | 06:47 AM
AFR logging is available if you select beta firmware or the beta version Access Tuner Race.
- Chris
Old Dec 23, 2013 | 09:50 AM
ikt's Avatar
ikt
- Chris
recent re-release then? I'll go for the update, thanks
Old Jan 3, 2014 | 04:37 PM
nqramjets's Avatar
+1 for the analogy, that's actually quite good...
Tony Harris
Cobb AccessPORT
Mar 12, 2017 07:10 PM
ckevoxnyc
Cobb AccessPORT
10
Jun 1, 2016 03:30 PM
rico05
Cobb AccessPORT
Apr 30, 2016 07:52 AM
wallie123
Cobb AccessPORT
Jan 28, 2016 11:11 AM
LJ7006
Cobb AccessPORT
Mar 3, 2015 09:10 AM
