stage 2 28 psi?
Old May 17, 2012 | 01:26 PM
egokiller's Avatar
stage 2 28 psi?
i have ams test pipe ams single removed boost pill and cobb ap. im running stage 2 right now everything is great but is it ok that im running 28 psi on a 2012?
Old May 17, 2012 | 01:27 PM
egokiller's Avatar
running 93 too forgot that
Old May 17, 2012 | 01:37 PM
3000GT-GTO's Avatar
Put back the boost pill first, 28 PSI will probably kill the turbo real fast.
Old May 17, 2012 | 01:48 PM
egokiller's Avatar
i just looked on the cobb website there are saying 28 psi is the target psi that sounds alittle high no?
Old May 17, 2012 | 01:51 PM
3000GT-GTO's Avatar
i guess if Cobbs Target is 28 then should be fine, I thought you were over boosting your target like me.
Where did you see 28 inside the map notes on AP ? ?
Old May 17, 2012 | 01:56 PM
egokiller's Avatar
yah it says 28 target boost taper down to 17 +- 1.5 psi
Old May 17, 2012 | 01:58 PM
egokiller's Avatar
i was running 26 psi on stage 1 to lol
Old May 17, 2012 | 02:15 PM
3000GT-GTO's Avatar
Even at 26 I am kind of Paranoid, most of the pro tune I see from people in New York
are all max at 24 PSI.
Have you tried using stage 2 91 vs stage 2 93 and see the Boost difference?
Old May 17, 2012 | 02:25 PM
egokiller's Avatar
no havent tried it. the way my car is running i dont wanna try it lol but if cobb is making all stage 2 people run 28 and stage 1 run 26 i guess its ok
egokiller's Avatar
where in ny u from?
Old May 17, 2012 | 02:35 PM
3000GT-GTO's Avatar
I am in Nassau County
Old May 17, 2012 | 09:20 PM
Optiblue's Avatar
and you're not getting any knocks?
Old May 18, 2012 | 03:58 AM
kbhdiaz888's Avatar
I have a 2012 and running stage 2 93 v200 boost pill removed. I have never seen the boost go 28psi. Max i have ever seen on mine is 26.5. I believe it says on the notes 28 +/- 1.5psi on boost target.
Old May 18, 2012 | 06:12 AM
egokiller's Avatar
zero knock the car is running amazing and im gonna see the a/f by tomorrow im waiting for my wideband to come in
Old May 18, 2012 | 06:14 AM
egokiller's Avatar
guess my turbo is better =p jkjk but i was running 26 psi stage 1 this turbo just wants to go and as of right now it runs amazing and pretty much spins all 4 tires its werid
