stage 2 28 psi?
that sounds a little high. if i were you i would call cobb and talk to them about it to make sure, especially because you have a brand new car
i wouldnt want anything to happen to it..
I'm having the same problem. My 2010 GSR only has 16300 miles on it and I hit 28/29 PSI then it holds in the higher RPM’s at 19 PSI . I have AEM intake, AMS turbo back and am on stage 2 -93. My boost pill is still in and to top that off in 3rd when I get on it hard the ASC service comes on. I going to run stage 1 till I can get in contact with COBB and see what’s the deal.
I just got the COBB AP, running Stage 2 AEM with no pill and its only going to 24 psi at 5,000 ft above sea level. For the engine I have AEM intake, catback exhaust, replaced hot pipe. 28 psi sounds high to me as well, you should def be sure its all good
GetterDragun
Oct 18, 2010 01:31 PM
dustin03
Dec 10, 2008 10:56 PM
