Ots maps for injectors??
Old Jun 12, 2012 | 06:54 AM
08gsrCoastie's Avatar
Is there any ots maps that include injectors? I have searched the Cobb website didn't see anything just wondering if I missed anything
Old Jun 12, 2012 | 07:08 AM
gsrboi80's Avatar
People have gone OTS map retarted
No you will need to have the injectors dialed in be it yourself, remotely, or live tuning session. The same CC injector from the same company may not be 100% the same.
So there is no way to safely make "OTS" mapping for larger injectors IMO
Old Jun 12, 2012 | 07:32 AM
Kracka's Avatar
Cobb used to have staged OTS maps available for DW800's and the 400S OTS map for DW850's. I know the 400S package is on hold for now, not sure about the other OTS maps though.
Quality injectors should be fairly consistent, within the parameters allowed by fuel trims at least, just like the OEM injectors are.
Old Jun 12, 2012 | 07:39 AM
I just found a stage 2 +ams intake + dw 800cc . Do you guys think this is a bad idea or is this safe to run on a dd car? Just trying to save a trip to get a tune
Old Jun 12, 2012 | 08:46 AM
gsrboi80's Avatar
I would def recommend logging the car in various conditions if you go that route
Old Jun 12, 2012 | 08:53 AM
I've been reading more in the Cobb forums seems like those maps are only for guys who don't want to pay to get injectors put on an this tune will get them to the shop but has no hp gains what so ever this sound correct ?
Old Jun 12, 2012 | 09:19 AM
Kracka's Avatar
Larger injectors will not increase power, only allow you to support more power. Unless you need larger injectors, don't bother. If you're attempting to run E85, then yes, you will need larger injectors, but the stock injectors are plenty capable of handling anything the stock turbo can do on pump gas (with a higher flowing fuel pump backing them).
Old Jun 12, 2012 | 09:33 AM
Ya can't run e85 not in my area but that clears up alot thanks for all the help
Brokeassevo
Cobb AccessPORT
Jul 26, 2016 08:32 AM
boyvang
Oct 6, 2015 05:56 AM
evoooo
Sep 19, 2015 03:19 AM
EvOx!
Feb 10, 2015 06:34 AM
Methodical4u
Dec 31, 2009 05:40 PM
