Which ots map?
Old Sep 17, 2015 | 03:14 PM
evoooo's Avatar
Which ots map?
I have k&n filter mod, stock dp, straight test pipe, single exit muffler no resonator. Im looking for a ots map for my ap just for temporary use (so i can drive) until I get more parts for a pro tune. I have only ran 93 in the car since new. Can I run a stage 2 ots tune for the time being or should I wait before I install the test pipe? If I wait on the test pipe which ots tune should I use? Thanks. I have searched but most senarios close to mine people have asked with aftermarket dp...
Old Sep 18, 2015 | 10:01 AM
evoooo's Avatar
I assume I can run the sf tune since its basically the same as filter mod. Or no? If it is, can i run stage 2 93 with my straight test pipe? I have stock downpipe so if anything I will run a little rich? Any help or advice would be appreciated. Ive reached out to cobb with no response. Thanks
Old Sep 18, 2015 | 03:11 PM
.M.'s Avatar
.M.
If cone filter and test pipe, I would run...
http://www.cobbtuning.com/maps/2013-...stage-2-sf-map
If drop in filter and test pipe, I would run...
http://www.cobbtuning.com/maps/2013-...age-2-chff-map
^I ran that for a couple months with a panel filter, test pipe, aftermarket exhaust. No problems.
If the test pipe is not installed yet, run stage 1. Sorry, you wording is a little confusing. Unless I'm reading it wrong. Don't worry about the stock downpipe. The main issue is the test pipe or stock cat.
And I'm surprised Cobb didn't respond (emails or phone calls, not sure). They've been known to have great customer service. They normally respond to my emails within the hour and send over maps when I request them.
Old Sep 18, 2015 | 08:57 PM
evoooo's Avatar
Thanks for the response! Sorry if my wording is all over the place. I will try to make the question more simple. I am running cone filter, stock downpipe, straight test pipe, and 3" single exit exhaust with muffler. I want to run a 93 tune. Should I run stage 1 or 2? If stage 2 (which I assume since Im installing tp) which ots map will be the best for cone filter and straight tp? I think you understood me well enough with the maps you posted lol. AP should be here monday which is why Im trying to find out now. Currently only the cone filter is on the car. Waiting for ap before I intsall tp and exhaust.
Old Sep 19, 2015 | 03:19 AM
.M.'s Avatar
.M.
If that's the case, run stage 2 sf map posted above.
hispanicpanic
May 25, 2013 09:55 AM
evofan_08
May 12, 2013 12:08 PM
Arsenal4Life
Cobb AccessPORT
May 7, 2013 02:45 PM
KahoX
Cobb AccessPORT
Nov 14, 2011 07:34 AM
XstormtrooperX
Jan 12, 2011 03:10 PM
