Stage 2 93 boost issues
Old Jul 28, 2012 | 10:07 AM
mac11wildcat's Avatar
Hey guys,
As title says, issues with Stage 2 maps.
Mods are:
Greddy Ti-C catback (full 3")
Custom test pipe
stock air filter and intake
Boost pill removed per Cobb instructions
When i run the Stage 2 93 map i overboost to a consistent 27.5psi
When i run the Stage 2 93 low wastegate map i underboost to a consistent 23.2psi
Can anyone shed any light on if the low wastegate map is supposed to underboost? Any reasons why im overboosting on the normal stage 2?
Old Jul 28, 2012 | 05:27 PM
MisterHappy's Avatar
do you just hit 27 and then go back down or are you holding 27. 27 psi isn't going to kill your car, i was running it for a while. What are your AFR readings like?
Old Jul 28, 2012 | 09:11 PM
ChipperEvo's Avatar
I believe the LWG maps are supposed to cut down on boost. I was waiting for the Stage 1 LWG map from Cobb but probably going to get a custom tune before those maps are available for the 2011.
Old Jul 29, 2012 | 10:27 AM
27.5 psi peak tapering down. didnt see where it tapered to. i saw the 2.5psi overboost and came straight back to re-flash the car.
Old Jul 29, 2012 | 03:58 PM
Uh i believe stage 2 is suppose to peak at 26 psi, so 27 isn't really dangerous.
Old Jul 29, 2012 | 07:59 PM
they say stage 2 aims for 25+/-.8. everything else is fine, including knock; so im not concerned now that everything else looks ok.
EEVOH
Cobb AccessPORT
13
Sep 23, 2013 09:30 AM
HELPr
Apr 19, 2012 08:19 PM
tinto1
Aug 2, 2011 04:23 PM
evo unknown
Aug 28, 2009 05:40 PM
weebles
23
Aug 13, 2009 08:50 PM
