Some accesstuner questions
Old Aug 5, 2013 | 12:08 AM
Blue_05EVO's Avatar
So I am running a stage 2 ots with sf cone. My ltft idle and cruise are all within 1.2% +\- my boost is only reaching 22 on lwg but is spiking 28 and getting 3 counts of knock on regular tune.
I have been reading and reading and it sound like from the accesstuner "how to" that all I need to Sonia lower the boost control load offset to lower boost in general.
But then when I read about other threads I get conflicting opinions!!
On my VIII I used a hallman set my boost to 26 psi
Then logged and used a rpm vs load reference to tune my Hugh octane and low octane maps as well as timing to meet afr. This was EASY lol
The x's are throwing for a loop on this accesstuner thing! And using te ecu for boost
Old Aug 5, 2013 | 01:26 PM
Blue_05EVO's Avatar
Bump for postin in cobb section
Old Aug 5, 2013 | 03:57 PM
btack's Avatar
OP, If you havent got this sorted out, lets see if we can get you squared up
Old Aug 5, 2013 | 04:30 PM
Blue_05EVO's Avatar
I'm still open for some info
Old Aug 5, 2013 | 04:31 PM
Blue_05EVO's Avatar
I would rather run the 93 normal waste gate and just turn the boost down to the 24-25 range
Old Aug 6, 2013 | 10:24 AM
acm_evo's Avatar
I'm interested in this as well. My car has the same symptoms. Stage 2 ACN non-lwg map spikes to 28.5 psi but then settles to a nice curve up to redline. I was able to eliminate knock count by taking out timing at the affected rpm-load areas, but i would still like to lower maximum boost to 25-26 psi as well, but not by using the boost offset parameters, because that would effectively lower the boost curve over the whole rpm range. I just want to reduce the boost spike I see at around 4000-4500 or so RPMs.
Old Aug 6, 2013 | 12:58 PM
Blue_05EVO's Avatar
^^^ this
Old Aug 6, 2013 | 11:18 PM
Blue_05EVO's Avatar
Old Aug 7, 2013 | 08:44 AM
btack's Avatar
What you need to do is use accestuner race, go into wgdc reactive, and adjust your levels and then test it out. I would do some research on it before attempting it tho. Read merlins guide to tuning evo x.
Old Aug 7, 2013 | 01:22 PM
Blue_05EVO's Avatar
I've read more and more and I'm learning that I'm gonna have to adjust the wgdc to control spike only thanks.
gtm_maxwell
Cobb AccessPORT
Sep 19, 2016 12:45 PM
A872B
Cobb AccessPORT
12
Jul 29, 2016 11:54 AM
COBB Tuning
Apr 13, 2016 12:53 PM
josedp
Mar 14, 2016 01:20 AM
JakeSoberman
Nov 30, 2015 11:28 AM
