Custom tune tomorrow. Boost pill removal?
Old Aug 23, 2013 | 10:01 PM
Vit0's Avatar
Hey guys have a question for you. I'm getting my tune tomorrow after finishing up my mods today. I just installed AMS FMIC, U&LICP, AMS intake, Cobb 3port BCS, tomei wide mouth, test pipe and exhaust. Do I need to remove the boost pill?
Old Aug 28, 2013 | 05:48 AM
Kracka's Avatar
The boost pill will already be removed as long as you used new vacuum hoses with the 3-port install. The two stock BCS should be completely removed, along with their associated hoses. You should have used 3 new hoses...one for each port on the new BCS
Old Aug 28, 2013 | 11:22 AM
murlo26's Avatar
Maybe I am misremembering, but I think you only need two hoses
Old Aug 28, 2013 | 11:32 AM
Kracka's Avatar
The 3rd port is supposed to run back to the intake pipe, if you set it up properly. A proper intake pipe will have 3 inlet nipples: BOV, crankcase ventilation, and BCS discharge. Not hooking it up this way is like intentionally building a small boost leak into your intake system.
Old Aug 28, 2013 | 11:42 AM
murlo26's Avatar
I wouldn't describe it as a boost leak, just letting metered air discharge and you now have a bit less than you think.
Maybe you could describe it as an "intermittent boost leak", but not continuous
I guess I have just always seen people show it as this way, including obviously big places like Perrin.
We have MAP tables to balance this off anyway, oh well. Maybe on my new intake i will get another bung for this.
Old Aug 28, 2013 | 11:47 AM
Kracka's Avatar
See the diagram I edited in above. Why build in an "intermittent boost leak" when you have the ability to create an ideal sealed system? Once the air passes through the MAF and it is metered, it should have no where to go other than eventually into the combustion chamber since the ECU is supplying the fuel for it.
Old Aug 28, 2013 | 11:50 AM
murlo26's Avatar
See the diagram I edited in above. Why build in an "intermittent boost leak" when you have the ability to create an ideal sealed system? Once the air passes through the MAF and it is metered, it should have no where to go other than eventually into the combustion chamber.
Don't know, never thought of it really haha.
I think I will rework my new intake to have this option. My car is so far removed from stock I don't remember all that it used to have. I think I might even add another line to my SSP catch can for the intake as well.
I won't argue its better to have what you show but I don't know if its completely necessary with the way our cars kind of average MAP and MAF calcs.
Anyway, moving on...hook it up like Kracka said.
Old Aug 28, 2013 | 11:54 AM
Kracka's Avatar
Whatever intake you get, it would be easy to add if it doesn't include it already. I had a metal Buschur intake pipe on my IX that did not include the proper nipples so I just got a few brass fittings from the hardware store, drilled two holes, screwed them in, and added a little sealant around them
Old Aug 28, 2013 | 11:55 AM
murlo26's Avatar
I'll just have MAP weld some on when they build my intake, problem = solved.
Old Aug 29, 2013 | 05:41 AM
Vit0's Avatar
Good thing kracka's close so I can pick his brain about stuff haha.
Old Aug 30, 2013 | 06:20 AM
Kracka's Avatar
haxr303
Mar 20, 2016 01:48 AM
superkizuna
17
Dec 15, 2014 03:27 PM
OC
Apr 15, 2013 08:33 AM
Grey Razor
Mar 21, 2011 10:55 AM
robyn402
Sep 12, 2010 11:43 PM
