Evo X Aftermarket Intake Calibration Guide
Old Jan 31, 2014 | 10:11 AM
COBB Tuning's Avatar
Originally Posted by .Adam
So I just checked the spreadsheet out for the MAF scaling and it looks like the K&N Panel filter is in there. Are these settings good for all EVO's? I have a 2008 GSR which is why I ask.
Also is it suggested to get the relay recall done before adding any edits to our current OTS maps? I just have a stage 1 stock OTS map with the K&N panel filter and I will be making an appointment to get the relays replaced soon.
Thanks!
Yes the settings are good for all evo's but the table size in the 2008 model year is different for Map Based Load calc. Check out the video at 3:30 to see what you have to do differently.
Old Jan 31, 2014 | 10:35 AM
.Adam's Avatar
Yep I've watched the video and know what I need to do. Thanks for the clarification though and thanks for the quick reply!
Old Feb 1, 2014 | 04:53 PM
jdizzle37's Avatar
This was super helpful! I was running the Stage 2 + CHFF map (Cosworth filter though) and was able to install my Cobb EBCS and modify the MAF scaling and load tables for the Cobb filter. Now I'm able to run the Stage 3 OTS map with 0-2 counts of knock and hitting 25psi of boost with no issues.
Thanks Cobb!
Old Feb 4, 2014 | 07:38 AM
.Adam's Avatar
I'm really impressed with how well the calibration is working.
Before the calibration I was getting a little knock on a daily basis.
So far I have had 0 knock at all!
Thanks Cobb!
Old Feb 5, 2014 | 08:19 AM
K&N Typhoon intake has been added to the spreadsheet. The AEM intake changes the diameter of the lines going to the boost control solenoid which can cause overboosting. We are putting together a tech document outlining how to safely run the intake with our OTS maps. Stay tuned for an update in the next few days.
-Eric
Old Feb 6, 2014 | 08:44 AM
AEM Intake data has been added to the spreadsheet. You will need to make the proper vacuum line adjustments outlined, and you will also want to start with a low wastegate map as the base for the changes.
-Eric
Old Feb 6, 2014 | 03:58 PM
ralliartatl's Avatar
Eric
I have an aem intake but I put the Cobb tih on because the aem wouldn't fit with the Cobb bov return pipe. Will this table still work for me?
Old Feb 6, 2014 | 06:29 PM
Originally Posted by ralliartatl
Eric
Th turbo inlet will not effect the tune enough to make much of a difference. You should be good to go!
-Eric
Old Feb 10, 2014 | 11:19 AM
.Adam's Avatar
Now that I have the K&N calibration installed on my stage 1 ots map I am getting a lot of knock mostly in 3rd gear when I mash the gas at around 3-4000rpm.
Has anyone else reported this to Cobb or is this just me?
Old Feb 10, 2014 | 11:24 AM
SOG RA's Avatar
Already made a thread but no access to pc to swap tables anybody have a clue how I can get kn panel maps for my '10 x se? Cobb cant help me out they dont have the maps.
Old Feb 11, 2014 | 09:13 PM
butters149's Avatar
For the AEM calibration, would we start with the regular Stage 1 LWG ACN91 or the Stage 1 + HFCC LwG ACN91 map to modify the values.
Old Feb 12, 2014 | 09:08 AM
Just the regular Stage 1 LWG map. CHFF is a COBB high flow panel filter map, which is already adjusted for our specific panel filter.
Old Feb 20, 2014 | 04:09 AM
Jossue's Avatar
I got the same result I went from 2-3 counts to 10- 13 and I'm on the LWG 93 oct stage 1 I have a K&N panel filter......
Old Feb 20, 2014 | 05:50 PM
EAGLE 5's Avatar
Boo I fail you don't happen to have an older excel version of the file do you?
EDIT I: I got open office to open the file I should be good.
EDIT II: Can this be used on the Stage 0 map to simulate stock tune or not really?
EDIT III: Got it up and running and the car runs great!
I'm using the 91 octane map (so I can travel to other states with lesser gas) and I got only 0-2 counts of knock and that was hitting boost hard in 5th gear on an uphill bridge. SOLID...
Old Feb 21, 2014 | 09:03 AM
.Adam's Avatar
Damn, well I dont get 10-13 counts of knock but I will get 1-3 counts under load at low RPM and in 2nd/3rd at about 4000-5000rpm.
I'll send some logs to Cobb when I can go through the gears. Right now it's just too slippery everywhere.
Question about LTFT: what if the levels are above or below 5%?
NVM, I read up on LTFT and understand how that works
