Evo X Aftermarket Intake Calibration Guide
Old Mar 24, 2014 | 10:55 AM
  #31
zer165's Avatar
Originally Posted by COBB Tuning
Just the regular Stage 1 LWG map. CHFF is a COBB high flow panel filter map, which is already adjusted for our specific panel filter.
Eric, Would you guys be planning to add the aFe intake to your excel list at all. Right now I'm using the Cobb SF map stage 3 but am getting some knock.
Old Dec 2, 2014 | 05:37 PM
  #32
cmoore's Avatar
Running stage3 91 v403.ptm on a 14 evo with ETS TBE, Grimm 3 port, and ETS intake.
I consistently get 0 knock sum with 25psi peak and 24 hold to redline. Do I even need to scale the intake?
Old Dec 7, 2014 | 04:56 PM
  #33
JonGonzo's Avatar
Yes! Check your LTFT and STFT. Changing your maf scaling is simple, just do it.
Old Dec 8, 2014 | 12:51 PM
  #34
cmoore's Avatar
Unscaled LTFTs was:
* -1.5 idle to 2700
* 0 from 2700 to 4600
* -1.5's from 4600 to 6300
* -3.1 from 6300-red)
After scaling LTFTs and STFTs are pretty much 0's across the board (couple -0.2 's here and there)
On the downside:
- I lost almost 3 psi of peak boost though. but I can 5th gear spike it higher now (26.5)
-picked up some knock sum (2s and 3s from 5180 to redline)
I think she ran better unscaled.
Old May 14, 2015 | 07:46 AM
  #35
Kreeker's Avatar
Is there a similar guide for evo 8 / 9? I'm toying with the idea of buying a v3 accessport for my 9, but I'd rather not be locked in to the cobb intake if I want to use one of the OTS maps.
EDIT: Wow it looks like Cobb no longer supports the evo 8 / 9... I had no idea. There goes that idea
COBB Tuning
Oct 14, 2016 12:00 PM
COBB Tuning
Apr 13, 2016 12:53 PM
COBB Tuning
58
Jun 17, 2011 11:28 AM
COBB Tuning
242
Sep 4, 2010 06:55 PM
COBB Tuning
Jul 6, 2010 03:57 PM
