ap tune help
Old Feb 15, 2014 | 11:39 AM
newevoxguy's Avatar
ap tune help
Mods are ets 3.5 ic and upper and lower piping tbe recirculated dp and test pipe and 3 port so can I use stage three tune till I get a real tune
Old Feb 15, 2014 | 12:07 PM
cravnpup's Avatar
I believe the stage 3 maps are designed to be used with the Cobb intake. If I were you, I'd start with the stage 3 map and use the intake calibration guide for a panel filter to get close to the stock intake calibration https://www.evolutionm.net/forums/co...ion-guide.html
After that's done, load the map and monitor knock and LTFT's. As long as you see no knock and your LTFT's are within +/- 5% or so, you'll be fine until you get a real tune.
Old Apr 5, 2014 | 04:04 PM
Sj119808's Avatar
id say get a custom map made from a pro tuner in your area that works with cobb. cobb told me that the 3 port doesn't work well with the ap. i could be very wrong tho haha i know that their own boost controller would be a lot more compatible with the ap.
Old Apr 6, 2014 | 12:38 PM
COBB Tuning's Avatar
Sound advice, one note is you can always get your stock intake calibration by loading a stock tune's MAF calibration in ATR and pasting it into a stage 3 tune. I would look into getting an intake, stage 3 levels of power are at the limit of the stock box.
Stage 3 is specifically designed for a 3 port boost control solenoid, you might see some pressure variance if you do not use our boost control solenoid.
-Chris
cKunz
Sep 28, 2016 05:03 AM
380EVO
Evo X Dyno Results
Sep 14, 2016 07:01 AM
On3go
Feb 14, 2015 07:33 PM
Dynotech Tuning
Aug 12, 2013 06:10 AM
EVO8LTW
Jul 20, 2009 05:49 PM
