Analyzing AP Datalog
Old Jun 2, 2014 | 08:00 PM
the 10th 1dr's Avatar
Howdy All. Just installed my APv3 and like so many before me, I was wondering if some of the more knowledgable minds on this forum could glance over my first data log, however, I have no idea on how to get the log from excel and place in my post. Can someone direct me to the correct answer. I have been trying to find it but can not. Google has not been helping me at all. Thanks in advance for your time and help.
Old Jun 3, 2014 | 07:26 PM
Bump for help.
Figured it out. Can some of the gurus take a look at my data log. Included the same map just in a txt file and a pdf file. Thanks in advance for taking the time.
File Type: pdf
File Type: txt
Old Jun 4, 2014 | 06:28 AM
COBB Tuning's Avatar
What map and fuel are you using, also what mods are done to the car?
- Chris
Old Jun 4, 2014 | 07:04 PM
Thanks Chris for the reply. I am only running an ETS intake with the stock MAF sensor. I am running the Stage 1 93 v403. I am observing about 3 knock sum in higher rpms from 5,000-7,000. I am not sure if the OTS maps are suppose to run like that but i just want to be on the safe side. Runnng the stock map I get a knock sum of about 2, so im not really sure if the OTS map is that much worse than the stock map when it comes to knock sum. Thanks again for your response.
Old Jun 4, 2014 | 07:07 PM
Chris, forgot to add that I am using 93 octane fuel. Thanks.
Old Jun 5, 2014 | 09:40 AM
You do have some knock on the top end, this might be bad quality gas, I would switch to the 91 map and see if the level of knock goes down. Also, you need to scale your map for your intake, you can follow the guide here, your fuel trims are off by about 8%.
-Chris
Old Jun 5, 2014 | 12:35 PM
Ok. Thanks for the advice. I will try the 91 map. I also have a mac so i wont be able to adjust the intake scaling unforunately.
Chet3215
Jul 24, 2016 11:51 AM
evo-87
Apr 19, 2016 11:49 AM
EvoOtto
Oct 29, 2015 02:05 PM
EvoXman23
Oct 22, 2013 12:19 PM
Mad_SB
Sep 6, 2004 03:09 AM
