Cobb Stage1+CHFF 93 v403 Map, 2014 GSR Dyno Results
Posted these results in the Dyno forum as well..
Just bought a Cobb tuner and installed the Stage1+CHFF 93 v403 Map, using the Cosworth drop-in instead of the Cobb. Boost hits 24.5 consistently, Knock typically hitting 1s at certain points in the RPM Range, occasionally a 2. HP tops about 265/TQ about 290 on Dynojet.
It feels a little faster, but nothing really dramatic. Turbo lag is greater, boost hits harder...not sure I love it really. Not sure what I should expect from the OTS tune..Currently debating buying the AMS STX300 to see if I can get a bigger lift w/out bolt-ons for now.
Thoughts??
Thoughts??
The AMS tune is a huge improvement over Cobb's OTS map. Smoother, almost no knock detected and pulls a great deal stronger. I was logging 3-5 counts of knock consistently under WOT with Cobb's CHFF93 map. I did a review back in March if you wanna read - https://www.evolutionm.net/forums/ev...ne-review.html
ckevoxnyc
Cobb AccessPORT
10
Jun 1, 2016 03:30 PM
MikeRupp
Evo X Dyno Results
Sep 3, 2014 12:55 PM
