E85 OTS MAP for X?
Old Aug 19, 2014 | 08:28 AM
Hotevo3's Avatar
E85 OTS MAP for X?
Hey Cobb,
Do you currently have any OTS maps for E85 for the 2008+ Evo X? I understand this would require a fuel pump and injector upgrade. Let me know!
Old Aug 20, 2014 | 01:37 PM
cravnpup's Avatar
No. You'll need a tune for E85 along with the injectors you decide on.
Old Aug 20, 2014 | 01:41 PM
20EvoX12's Avatar
Cobb will most likely never come out with a tune for e85. Ethanol content varies from each state and season. It will be way too dangerous to have a OTS E85 map, so like cravnpup said, no you need a custom tune for E85.
Old Aug 21, 2014 | 09:08 AM
bgemk911's Avatar
So, along with the tune, all you need convert is fuel pump and injectors? the fuel lines will handle e85?
Old Aug 21, 2014 | 09:19 AM
COBB Tuning's Avatar
Yes, that's all you will need. Like mentioned before we will most likely not be releasing OTS maps for E85 anytime soon without a flex fuel solution. Our E85 varies from 80-70% depending on stations around Austin. This variance makes it hard to develop a tune that will be safe everywhere in the country. Your best bet is to go to a Pro Tuner and get an E85 tune in your secondary map slot that is compatible with the ethanol content that you have in your area.
-Chris
WickWhiteEvox
Cobb AccessPORT
Mar 12, 2017 09:50 PM
Brokeassevo
Sep 17, 2016 08:36 PM
boyvang
Oct 6, 2015 05:56 AM
COBB Tuning
Cobb AccessPORT
95
Sep 24, 2015 07:35 PM
valin
Cobb AccessPORT
Nov 14, 2011 08:03 AM
