Cobb stage 1 not hitting proper boost help
Old Jul 10, 2015 | 10:35 PM
Turcs's Avatar
Edit* Data logs
Hey guys
I recently bought the ap for my evo X gsr and ive tried 2 stage 1 map and im not reaching the +/- 23 psi
Im only reaching 14.
What could be the problem ?
Thank
File Type: csv
File Type: csv
Old Jul 11, 2015 | 11:52 AM
Turcs's Avatar
Anyone ?
Old Jul 11, 2015 | 12:18 PM
Apexaholic's Avatar
Are you running any other mods on the car? I know I was having issues when I first put my UICP on because I didn't tighten down the T bolt clamps enough. You may also want to do some data logging to see what the issue is.
Old Jul 11, 2015 | 12:43 PM
Turcs's Avatar
Im running a cat-back, intercooler with upper and lower pipping and intake. But when i wasnt using cobb i was reaching 16 psi so i dont think i miss tighten my things.
I will do logs today and post it for u guys
Old Jul 11, 2015 | 12:54 PM
Turcs's Avatar
Heres a logs i did yesterday
Sry for the long logs just go around 2483 sec
At 4612 you can see me reach 14
I know im not pushing it hard but u might see sometings i dont and i will post 1 later when i give it hard and you will see the psi dont go over 14
File Type: csv
Old Jul 15, 2015 | 09:28 AM
hoobastnk90's Avatar
Well i see where you got on it for a couple seconds but never went above 3k rpms do you have a few pulls where you reach higher rpms? Or does it still not build boost as the rpms increase? But yea it should be spiking a lot higher if you go full throttle at those rpms. Are you sure you dont have a boost leak? Did you already do a boost leak test?
Old Jul 15, 2015 | 11:33 AM
Turcs's Avatar
Theres my 2000 to 7000 rpm pull log on the top of the thread.
The boost dont increase as the rpm go.
No i did not do a boost leak test is there an easy way I can do it myself
Old Jul 15, 2015 | 11:47 AM
just wondering if you unistall the ots map and just goto a stock map does it still have the same problem?
Old Jul 15, 2015 | 12:26 PM
Turcs's Avatar
U mean instal stage 0 map or factory map i was reaching 16 psi before installing cobb stage 1 at the very max but ya it was approx the same boost
Old Jul 15, 2015 | 01:49 PM
Well its pretty safe to say then you most likely have a massive boost leak then. I would go through and check all the piping connections. Because you should be spiking to 26 or 27 lbs of boost then tapering down to 17 or so. If you google search there are tons of ways to do boost leak checks. Easy way is to just get a squirt bottle of soapy water and spray the joints and if you see bubbles then your leaking there!
Old Jul 15, 2015 | 01:56 PM
jakeleclair2000's Avatar
This ^.
Do the leak check as soon as you can. Boost leaks can cause the turbo to overspeed and go bye-bye. Dont want that.
Old Jul 17, 2015 | 01:12 PM
wallie123's Avatar
Get a 3 port and run Cobbs stage 3.
I had the same issue and the 3 port seemed to fixed it
Old Jul 17, 2015 | 09:25 PM
Turcs's Avatar
Dont we need all of cobb stuff to be stage 3 ?
Old Jul 18, 2015 | 04:15 AM
wallie123's Avatar
I run a modified version of Cobbs stage 3 with the stock downpipe and catback although I have Cobbs 3 port, ams test pipe, cai, intercooler, uicp, licp. i have no issues
If buying a 3 port is not a option. I would suggest checking the stock ebc, the lines may be hook up incorrectly
FYI if the intake you have isn't from Cobb you'll have to modify it to avoid any issues with the a/f
Old Jul 21, 2015 | 07:26 PM
Turcs's Avatar
Ok I will check the ebc lines.
Where did you get your modified cobb
