Stage 1 OTS map with ETS upper intercooler piping?
Old Jul 22, 2016 | 06:49 PM
Brokeassevo's Avatar
I'v contacted cobb to see if it would be safe to use a OTS stage one map with a ets uicp. They weren't 100% sure, said it should be fine. They said my cat back and drop in filter shouldn't be a issue, but I'm still concerned about the uicp. Cars a 2015 gsr
Is anyone using a after market uicp with the cobb stage one map?
Old Jul 23, 2016 | 08:46 AM
Rado_93's Avatar
You will be fine. The UICP isn't one of those "tune necessary" mods.
Old Jul 23, 2016 | 08:50 AM
What about the panel filter they said it should be fine but there website says stock air box/ stock filter for OTS stage one
Old Jul 26, 2016 | 06:44 AM
.Adam's Avatar
I have the same hard pipe and stage 1 OTS tune and it's fine.
What panel filter do you have? You can always use one of Cobb's calibration's to modify your tune to utilize that filter.
https://cobbtuning.zendesk.com/hc/en...on-Spreadsheet
Old Jul 26, 2016 | 07:43 AM
I have the cosworth drop in panel filter
Old Jul 26, 2016 | 08:32 AM
.Adam's Avatar
You can always try the calibration for the K&N or the COBB panel filter. You might want to clarify that with COBB but when I had a K&N panel filter I tried both and the COBB filter calibration actually worked better.
Brokeassevo
Sep 17, 2016 08:36 PM
03redtype-s
Oct 17, 2015 06:02 PM
3000GT-GTO
Evo X Dyno Results
Dec 20, 2013 10:06 AM
ETS Michael
EvoX 'For Sale' External Engine / Power
65
Jan 8, 2013 02:45 PM
assembeldbygod
16
Jun 28, 2008 07:58 AM
