AEM Intake 2015 evo x gsr
I have a 15 gsr. Planning on installing test pipe and 3" single exit exhaust this weekend. I installed a AEM box intake yesterday under the recommendation of my friend that works in a tuner shop. Come to find out that Cobb no longer support AEM intakes. Does anyone currently run this setup and if so what map are they using from Cobb. Or is there stage 2 normal wastegate ok to run?
Do you have Accesstuner race? If not, apply on the cobb site with your accessport serial number. If thats all the mods youve got, i suggest going stage 1. Make sure you're using a map that supports the factory Boost controller.
What you need is a MAF calibration. There are a number of good tutorials on EVO forums. Heres one that I thought was well written.
http://www.evoxforums.com/forums/showthread.php?t=18023
However my friend, you're in luck. Cobb no longer supports AEM intakes, they do however have a write up on how to make it work, follow the tutorial carefully:
https://cobbtuning.zendesk.com/hc/en...on-Spreadsheet
Please do look up AEM data on the spreadsheet, it shows you how to hook up your vacuum lines to prevent overboost conditions. I suggest you take it back to your tuner friend to make sure its all done correctly.
Firebat
Evo X How Tos / Installations
Nov 29, 2016 06:49 AM
EVOFans
Oct 9, 2015 10:36 AM
