Discussion / Rumors The rumored Mitsubishi Lancer Evolution XI. .What have you heard? What do you think?
HELP WANTED code p0171
Old Jun 9, 2022 | 01:29 PM
IDK123's Avatar
Has anyone out there, self fixed the code p0171?
Ive called the Mitsubishi parts department & they said its more than likely a vacuum leak.
I've tried to use a leak detector solution in the engine bay while idling, and no luck finding the vacuum leak. Any suggestions would be great before i pass the car over to a mechanic.
2011 EVOX
Old Aug 13, 2022 | 04:58 PM
SsZERO's Avatar
I would recommend that you check and/or replace the boost lines going to the diverter valve and boost controller. If you are still using the stock ones, they could have worn out or there might be a crack in one of them. They are easy and cheap to replace with quality silicone hoses that won't wear out from being exposed to high underhood temperatures.
timschoeliertm
Lancer Troubleshooting
Jan 26, 2012 09:50 AM
09Ralli
Apr 3, 2010 10:40 PM
Johnny Boy
Lancer Engine Tech
Jul 13, 2007 05:16 PM
P0411
Mar 2, 2006 08:25 PM
