just came back from LACR-palmdale
and im frustrated with my times....the conditons were pretty decent i suppose...maybe mid to high 70s tonite....here are the results...im still tryin to get better so please help
1st run
RT - .434
I1 - 2.202
I2 - 6.184
I3 - 9.616 @73.694
I4 - 12.385
et - 14.950 88.33
2nd run was a little better but still not good enough for me
rt - .657
I1 - 2.086
I2 - 5.993
I3 - 9.276 @75.697
I4 - 12.007
et - 14.493 @92.069
3rd run i feel was better but i dont know why the et came out the way it did
rt - .380
I1 - 1.940
I2 - 5.850
I3 didnt give me a reading..i think it was messed up cuz none of the slips showed the i3 in the left lane..all others were in right lane
I4 - 11.976
et - 14.472 @94.313
okay so i knoe lacr is a slow track but with that last run should i have broke 13s or even 14 flat??what did i do wrong....hmmm please help anyone..i knoe these times r slow for my stock evo but im still new to this awd turbo so im trying to get better..
1st run
RT - .434
I1 - 2.202
I2 - 6.184
I3 - 9.616 @73.694
I4 - 12.385
et - 14.950 88.33
rt - .657
I1 - 2.086
I2 - 5.993
I3 - 9.276 @75.697
I4 - 12.007
et - 14.493 @92.069
rt - .380
I1 - 1.940
I2 - 5.850
I4 - 11.976
et - 14.472 @94.313
I am no professional but have been to palmdale many times.....my .02 is that your launches are not good, with the stock clutch 1.8xx all day on a bad day, 1.7xx on a good day. Other then that I like shifting around 7300-7400 each gear, when you shift you have to shift as quick as possible hope you don't miss on a stock clutch and your car should be good for high 13's at palmdale. Fastest I have seen is some where around 13.4 for a stock evo at palmdale. Remember palmdale is also known for wind in your face and the elevation slows you down a little. Hope that helps see you out there.
Looking at your trap speed tells me your running out of power at the top end.
Could be a lot of things...boost leak, shifting , ecu pulling timing, ect..or like seywen said..maybe a 40mph headwind.
The last run with a 11.9 1000ft. should've got you close if not into the 13's.
Don't feel too bad, I thought I was the only person to not break 13's at the track. My first time at the track was 14.3, 14.2, 14.19 and finally a 14.009. What worked best for me was to launch at 6K, shifting at 7200rpms.
Other evos at the track have been running the same low 14's as well..
i know i dont have a boost leak..i recently did a test and there was no boost leak....also im hitting full boost at 19-20 according to my gauge...i might have shifted a little early from 3rd t0 4th but i still should have hit at least 14 flat...my evo is stock...what is ecu timing?...another thing that i noticed was i ran an older M5, and beat it with no infractions..and it still said my timing was slower then the m5??dont get it..could the times possibly be slightly off?
Practice will make perfect. Amazing what a difference it makes. My average times were 14.1-3's. Finally last weekend with better launching, and shifting I got my best yet of 13.732. that's a .3-.6 difference..
1st run
RT - .434
I1 - 2.202
I2 - 6.184
I3 - 9.616 @73.694
I4 - 12.385
et - 14.950 88.33
rt - .657
I1 - 2.086
I2 - 5.993
I3 - 9.276 @75.697
I4 - 12.007
et - 14.493 @92.069
rt - .380
I1 - 1.940
I2 - 5.850
I4 - 11.976
et - 14.472 @94.313
1st run
RT - .434
I1 - 2.202
I2 - 6.184
I3 - 9.616 @73.694
I4 - 12.385
et - 14.950 88.33
rt - .657
I1 - 2.086
I2 - 5.993
I3 - 9.276 @75.697
I4 - 12.007
et - 14.493 @92.069
rt - .380
I1 - 1.940
I2 - 5.850
I4 - 11.976
et - 14.472 @94.313
California Speedway http://www.californiaspeedway.com/tr...niaDragway.jsp
Perris Auto Speedway
http://www.perrisautospeedway.com/site/souvenirs.html
Irwindale Drag Strip (1/8th mile only)
http://www.irwindalespeedway.com/dragstrip/index.asp
Famoso Raceway
http://www.famosoraceway.com/
With that said, your times at LACR can improve, your 60ft needs work, and probably your shifting too. With better launches and better shifting, you should be able to hit 13.9 or 14.0 at LACR. which isn't all that bad, that's like a 13.5 or 13.6 at a better track. So just use LACR as a tool to improve on your driving skills. Good luck and keep practicing.
3000ways thanx for the info....yea i plan on ogin to cal speedway sometime soon....i do need improvement thats what practice is for...but when i first bought the car i was runnin high 14s low 15s...haha...but i can tel imm gettin better..thanx all for the help..pece
LACR is a difficult track to get good times at. I use to live Lancaster/Palmdale and would hit the track religiously. My best time w/ intake, cat back and afc untuned was 13.9 with a 1.9 60ft. LACR is a very challenging track.
