Launching a 05 Evo??
I have been testing it out,, but have not been able to establish a correct spot. I have not gone higher than 3K, becuase i know how the cluctches go so easily.?
Any Suggestions Comments::
yeah but the clutch is meant to slip so that the drivetrain doesn't break. But you can launch over 3K. Just be smart don't pop the clutch, but don't slip it neither. My friends EVO VIII, which is different but whatever, the best launch I ever got out of it was at 4.5K and not dumping the clutch but just a quick slip so that it rolls out instead of launching, and as I let go of the clutch I mashed the gas pedal. Got a couple of chirps and away it went. Try it don't be scared to experiment, just don't do nothing crazy or stupid. Go up little by little once you get a good launch your good.
For the 05, I got good results lauching at around 4500-5000 rpm. Just quickly slip the clutch out with the gas pedal in (like you are doing a balance scale). Don't drop it.
Originally Posted by 05WhiteEVO8
Just use the launch control, bounce it off that, hold the gas down and when you feel the clutch starting to engage drop it and your off.
The 05 does not come with launch control!! If it does please tell me how to adjust it for 6100 thats where I would like mine. It comes with a rev limiter in 1st set at 5000ish. Trust me you need more rpms for consistant launches on the drag strip. You don't need as many rpms on the street the surface is not as sticky so maybe 5000 will get it done on the street but not on the track.
Try searching....for 5K, launching, 5000...
Saywhen - wrong, and wrong, and wrong...so you think a 5k stutterbox launch and 1.71 60' is bad. It all comes down to how good the car is set up and how the driver can use what hes/shes has. 03/04 did not have this feature. Only 05 and up. 5000K works fine for those who know how to use it - period.
05EvolutionRS - Clutches do not go that easy - poor driving makes them go.
Flamered05SRT - Evos come with a restrictor in our clutch line that forces the clutch to slip when let out fast. Thats what causes most of the slippage in our clutches.
05s come with a 5K factory stutterbox - to keep drivers from launching at 7k and blowing something up. But the 5K works great for launches.
when i did my 12.8 pass i hit mine off the 5k rev limiter and got 1.844- 60". you just have to feel the car. once it starts to roll alittle bit you can take off. but not like a dump off. it feels like your car takes off like a rocket.
