Turbotrix Reflash = Personal Best ET 12.23
Originally Posted by Dropspeed
Yes, I am sure there are no cams
I was running 4 gallons of 100 mixed with 4 gallons of 94 pump. So 98ish?
Oh, well that explains it. Nevermind. Decent job nonetheless, but you had us thinking this was on pump gas. I pick up a good 30whp with just a mix of 104/93, but I do turn up the boost and lean out the SAFC, which is how I hit 113+ mph on stock cams like you. I hit my 12.0s and 113mph with only 89-90 in the 1/8th-mile, though. I'm pretty skeptical on you hitting 93+ mph in the 1/8th, which requires about 375whp to accomplish.
OK newbie Turbo owner question, Is race gas worth it on a car with no control over the ECU/or boost.?
What kind of power gains do you see by just pouring in some 100 octane?
Mattj
Sorry for the confusion, I just through the race gas in for the hell of it.
Mattj
Mattj
how come i ran 12.48 and 110mph with 380whp-400whp and methanol injection runing28psi??? that was first time at the track ever,,,, but its too slow for the mods i have...
i thought i did best....i think its about how to shift gear fast... how u guys shift>???
u punch the clutch pedal and let go fast while u shift quick>? give me some tips
Originally Posted by money pit
great run matt.
i can vouch for matt's crazy driving. after watching him roadrace for years its a miracle that he hasnt blown up the evo yet, haha.
I have put more miles on the EVO this summer than the other two cars combined over a 2 year period and only needed to replace (upgrade) the clutch.
................I'm going to try to go back to the track one more time before the snow flys here and run on straight pump gas and then add 4 gallons of 100 for a back to back comparision.
Mattj
Dyno's don't always tell the truth. The track always tells the truth, though. If you really are putting down 380-400whp, you should have traps speed from 118-120mph. I do 110mph with 300whp on pump gas without cams and 21psi...
if i shif gears fast then my 1/4 speeds will go up from 111mph to like 118mph?
i got dynoflash dyno tune and had 330whp and 2nd time i had dyno flash street tune with methanol kit ......got cams...etc except stock turbo ...
