DOCILE GOES 8.3 @ 177mph
Old Jan 26, 2006 | 12:12 PM
evokiller's Avatar
Originally Posted by JUNEVO8
Try 1041HP ATW@2.6 bar (about 38PSI) boost at 9532 RPM. I think it is about 950-1000KG. It runs a PWR liquid to air barrel.
1000kg is very very light. no wonder they run fast. that's 2,200lbs. 1,000+ lbs less than street-driven evos.
Old Jan 26, 2006 | 12:14 PM
RallyCam's Avatar
Dyno sheet I've seen shows 1041Hp on a DynaPack Hub dyno.
Peak torque was around 7500rpm, power peaked at 9500, and run stopped at 10,000rpm.
Old Jan 26, 2006 | 03:13 PM
C6C6CH3vo's Avatar
Does anyone know if the car uses dry ice intercooling?
Old Feb 2, 2006 | 01:44 PM
TrinaBabe's Avatar
It weighs less than that and I am almost sure it does not have that much power. Ill see if I can dig up some posts made by them.
Old Feb 5, 2006 | 01:11 AM
yelo3's Avatar
It weighs 2300lbs with driver
Old Feb 13, 2006 | 12:17 PM
JUNEVO8's Avatar
POWER.
Old Feb 13, 2006 | 12:34 PM
Turbopit's Avatar
I doubt it with the barrel type liquid/air. The few set ups I've seen that used dry ice weren't set up like "most" air/waters with a tanked intercooler with liquid lines going to some type of chest/cell full of ice. Here in the states I'm not sure the NHRA would even allow the dry ice. I could be wrong.
Old Feb 13, 2006 | 12:38 PM
RallyCam's Avatar
I hear DOCILE ran a 8.23 @ 179.5 on Saturday. Which they say makes it the fastest 4wd 4G63.
Also ran an 8.4
http://championdragway.co.nz/id-8/it...ile-C7QDAT.TXT
Old Feb 13, 2006 | 12:52 PM
TrinaBabe's Avatar
Fastest perhaps but not quickest
