day at the track evo 9
I went to the track yesterday
Did 3 runs with my evo 9 I run 12.6 at 111.44 mph my 60’ 1.921 , (very cold) my tires
did not hook .I have to go when its little wormer like 60, it looks like I can do low 12 s or even high 11s
__________________
__________________
Originally Posted by evo9-power
????????? reflashed ??????????
i have similar mod that u do, except no dowpipe and with 20psi and i ran a 12.6@109 but my 60' was 1.7
If i get a reflash and the downpipe i should run 12.0, maybe 11's
Originally Posted by IE Evo
12.1 or 12.2 is more likely with his trapspeed.
Originally Posted by boostedwrx
I know you know IE, but remember the 9's make a lot more power under the curve where it matters. I've seen quite a few of low ETs paired with low trap speeds so far.
I'm also starting to see a lot of, "If I add this or that" or "If I could just get this 60'," speculation. People will soon realize that drag racing doesn't work that way. It gets harder and harder as you get lower and lower times. Just look at me. I ran a 12.01 while bouncing off my rev limiter for 50' at the end of the track. I figured with a flash that raises my rev limiter, I could easily snag an 11.99, since that would be another 2-3mph on the top-end. Well, I went back and ran the same 60' with a faster 330', 660', and 1000', but only got a 12.000 despite having that extra 2mph on the top-end. I gained 1/100th despite going faster and driving the same. Drag racing is finicky as many will soon learn...
__________________
__________________
Your times will not improve with warmer weather.
Nice numbers btw
