Gains with the EBAY O2 Housing?
Old May 25, 2006 | 08:31 PM
EVIL_EV0's Avatar
I think I'm gonna take my O2 off the car. Simply because I doubt its any better than the factory housing. Sure its a little lighter but on my car its harder to control boost.
The O2 should fit on any 8/9 evo. If you want mine I'll sell it fairly cheap. PM me.
Old May 26, 2006 | 06:38 AM
David Buschur's Avatar
Wow, surprised nobody has put a link up to the testing we did on that housing. I did test it back to back on the dyno, multiple times actually. Tested it against a good ported/ceramic coated stock housing. Definite, absolute gains with it. Almost 15 whp actually.
There is a thread about it in Engine/turbo/drivetrain.
www.buschurracing.com
Old May 27, 2006 | 03:12 PM
Jeff_Jeske's Avatar
What do you think about the fact that I can hold higher boost levels now?
I find it odd that prior to the housing my boost curve looked just like everyone elses but after the install, if I wanted to, I would spike to nearly 28PSI dropping to 24PSI at redline.
Old May 28, 2006 | 08:35 AM
Soon2BEVO's Avatar
You thought wrong. Read Buschur's post. Its a huge restriction and he even made that power over an already ported one!
I felt a noticeable difference after the 02 went on.
Old May 28, 2006 | 08:54 AM
Jeff_Jeske's Avatar
I dont know if I would say its a huge restriction especially if people aren't seeing the returns at the track.
Old May 28, 2006 | 09:06 AM
Soon2BEVO's Avatar
I didnt know so many people installed 02s and immediately tested it at the track. The fact stands, its a restriction as evident from the dyno before/afters, which are actually accurate. Also, Id say most people who installed them felt a noticeable difference. I deinitely did. I cant say that for most mods.
Old Jun 16, 2006 | 08:39 PM
EVOlution561's Avatar
The power gain is definitely noticible, when I installed my just recently I was thrown to the back of the seat harder than before especially at the top end, the only bad things about this is that I did hit 24psi today. I usually run see 22psi, I have never seen higher than 22 before the install, now I had to turn the boost down a bit because of it, the other bad thing is CEL i get from it.
Old Jun 16, 2006 | 09:46 PM
Soon2BEVO's Avatar
If youre getting a CEL there is another problem
Old Jun 18, 2006 | 08:21 AM
denile's Avatar
If you have a CEL for your o2,Its because you damaged it either from removing it or reinstalling it.Same thing happened to me.
I installed a new one and it is gone.
And Like was said gains are very noticable on the top end.But I have no overboosting problem.
Old Jun 18, 2006 | 08:31 AM
dan628's Avatar
Well it depends on which brand o2 housing you go with, people keep saying ebay parts, but it depends on the brand, ebay doesn't make parts, so you gotta make sure you get the right brand name.
Old Jun 21, 2006 | 06:21 PM
Dropspeed's Avatar
The power gain is definitely noticible, when I installed my just recently I was thrown to the back of the seat harder than before especially at the top end, .
Ahhh the "Back Dyno" how does this compare to the industry standard "butt dyno" ?
Mattj
Old Jun 21, 2006 | 06:35 PM
SKILMATIC's Avatar
It's too hard to measure on a part like this. You can have variations of 1-2mph or .1-.2s just based on the day, the weather, the track conditions, your gas, etc. A 10whp difference will only give you a .1s and 1mph increase, which is too small to give credit to a single part as opposed to a change in conditions. The dyno does not lie - if you do before and after and see consistent gains, then you know it made a difference.
I dont even know if its a .1 difference it may even be in the .01. However, a buddy of mine got a ebay 02 and the thing didnt fit. One of the bolt holes didnt even line up he ended having to dremmel out the bolt hole to make it fit.
On the contrary, another friend of mine got one and it worked fine. A matter of fact it looked identical to the helix.
Wick3d3vo9
Jan 22, 2009 10:54 AM
1BADEVO8
Feb 12, 2007 06:18 PM
Fusion7
Nov 19, 2006 09:34 PM
SlowCar
16
Jun 28, 2006 05:04 PM
eve-slow
Mar 16, 2005 05:19 AM
