ET/MPH gains from a test pipe.
Soon, I'm going to measure this. I'll first make several passes with the stock cat, then go to the pits, swap it out for a test pipe, and immediately making several more passes.
Anyone care to guess what this is worth? I'm guessing 1-1.5 mph on average.
Originally Posted by C6C6CH3vo
When I removed the cat I had to turn down the boost because it was 1-2 psi more. Heck yes more power - but you may loose most of it when you turn the boost back where it was
I am all about this test but the test is somewhat flawed. It would be much easier to test on an automatic car, but unless you are a great driver (and you probably are, but for arguments sake) shift points and launching can be a big factor. Sorry, just like to be devil's advocate. Good luck!
That's very true for ET consistency. But from my expereince, MPH is a lot more forgiving. For example, suppose you get a 1.7s 60ft time in one pass, then screw up on the next pass with a 2.0s 60 ft. Most likely, you'll be about 0.4s slower on the 2nd pass (a big difference). However, the mph will probably be very similar.
When I do this test, I'll put more weight on the MPH than the ET gain. Now if I can only get those damn rear bolts loosened, I'd be ready to do this.
Stock cat-back. Because I already have one loud car, I have no intention of getting a full TBE on the Evo. But I may eventually get an e-cutout on the downpipe for the drag strip (where I don't mind being loud).
