First Time at The Drag Strip
Old Sep 10, 2006 | 02:19 AM
Evo_Jay's Avatar
Well, I went to my local 1/4 mile tonight. Took the IX out for the first time. There was a nice turn out, but not many imports, mostly older american cars.
Heres the info...
The place
Redding drag strip - Elevation 490'
Temps
8pm - 73*
11pm - 67*
Humidity
8pm - 44%
11pm - 57%
The car
06 IX GSR (bought feb. 06)
HKS panel filter
WORKS 3" TBE
Boost controlled by ECUFlash & stock boost solenoid
Runs 1-3 - 21/20 tapering to 17/16
Run 4 - 22/21 tapering to 17
Stationary Limiter set to 5750
1/4 tank of 91 Octane
Removed Spare & Tools (-37lbs.)
Installed Sub & Amp (+57lbs.)
-------------RUN1----RUN2----RUN3----RUN4
Reaction---0.85-----0.81-----0.60-----0.78
60ft---------2.32-----1.95-----1.97-----1.90
1/8----------9.05-----8.57-----8.52-----8.40
1/8 MPH--81.11---81.01----83.46---82.40
1/4--------13.80---13.33----13.21---13.16
1/4 MPH-103.93--104.39--103.08--102.16
When I upped the boost by 1psi, as noted above, the car seemed weaker (according to MPH), but it was my best E.T.
I already know my launch is pretty bad, so flame away.
EDIT- added slips, I am car 172.
Attached Thumbnails First Time at The Drag Strip-run-1.jpg   First Time at The Drag Strip-run-2.jpg   First Time at The Drag Strip-run-3.jpg   First Time at The Drag Strip-run-4.jpg
Old Sep 10, 2006 | 02:52 AM
AZ EVO IX MR's Avatar
next time put in 104 even if your not tuned for it. you will see 12s. and when you get tuned for it lower 12s
Old Sep 10, 2006 | 02:57 AM
Evo_Jay's Avatar
I tried, but my local race shop was out of VP jugs of race gas and the place near the track that sells race gas closes @ 3pm on Sat. and I didn't get to that area till bout 6pm.
Old Sep 10, 2006 | 05:02 AM
3000ways's Avatar
A Manual Boost Controller could help, I have one and I hit 22PSI and have little to no taper.
Old Sep 10, 2006 | 05:12 AM
blackevo110's Avatar
hallman mbc $85-100.
5 gallons 100oct $20-30.
untuned with 2 more pounds of boost- 12.5
Old Sep 10, 2006 | 05:24 AM
Evo_Jay's Avatar
I don't need a MBC. Im working on complete boost control using the stock boost solenoid and am all most done (even for race boost).
Everybody has taper (with stock turbo & WGA), and anybody that says they don't is lying to themself. All my boost numbers are from MAP sensor logs.
Also, a couple post up, it says I tried to get some race gas but it didnt work out.
Sorry if I come off "WarrTalon style" (j/k Warr)
Anyways, I should be gettin a Jestr E-flash later this week
Old Sep 10, 2006 | 11:03 AM
Boltz.'s Avatar
FCOTM Winner
^ You'll notice that when you hit a quicker 60ft that your trap speed will go down a little bit, so thats normal.
The car is down on power though for a 9 with TBE. My 8 trapped higher stock, but it was on 93 so its not a direct comparison. Have you done a boost leak check yet? With those mods if you arent pulling timing you should be running 106-107 traps even with 91 oct.
Old Sep 10, 2006 | 12:48 PM
Evo_Jay's Avatar
Its been proven that a TBE on a IX doesn't do much without tuning.
I haven't done a boost leak test, but I have logged boost many times and there seems to be no leaks, but you never know, there probably is a leak or two..
but after reading thread bout 1/4 mile times of IXs in California, I'm some what pleased with the results.
Old Sep 10, 2006 | 12:53 PM
draconx's Avatar
slipping clutches suck .. hurry up and get that tune evo_kid... c ya l8rz
Old Sep 10, 2006 | 01:00 PM
o.e.boost's Avatar
i had about the same time as you...no tune, evo9 turbo, stock boost, full tbe, full weight...my 60ft times were 2.0 all day and the best run for the night was a 13.3@103.7mph, this was at famoso raceway...the weird thing though was that i had 2.2 60ft the first time and my trap was still the same
--im pretty sure i have boost leaks...or i thinks so...i'll be testing it when i install my nisei licp
Old Sep 10, 2006 | 01:58 PM
Boltz.'s Avatar
FCOTM Winner
I disagree with the TBE comment. its gonna give you a better boost curve, better response, and more top end because of less restriction.
Logging boost will give you no indication if you have a boost leak, fyi.
The results are not bad at all, it just seems the car should have a little more in it.
Old Sep 10, 2006 | 02:08 PM
ant_turbo's Avatar
What track did you go to?? Those times aren't that bad!! When I 1st started racing my evo_9 my 60' sucked!! But with practice and more track time my 60' where getting more better!!
Old Sep 10, 2006 | 02:24 PM
cj1977's Avatar
That pretty good. I imagine you are a good driver.
Old Sep 10, 2006 | 07:09 PM
Warrtalon's Avatar
Yeah, never rely on a boost log to determine if you have a leak or not. You will see the same boost numbers with a leak, but the turbo will be working harder to maintain that boost.
Car is very weak for such optimum conditions. However, it's almost impossible to run a 13.1 with only 102mph on a 1.90 60'. I can't imagine how in the world you did that unless the car was actually going a good bit faster most of the way down the track then started knocking up top due to the extra boost. This is not likely, though, considering how rich the stock tune is.
I know you're wanting to control boost electronically, but you'll eventually get an MBC when you get frustrated with the boost characteristics and get tired of going slow. you're right about the "no taper" comment, though. All these people keep saying, "With my MBC, I hit 21psi and it holds to redline!" All that tells me is they've never logged their boost with a MAP sensor.
Old Sep 10, 2006 | 07:36 PM
Evo_Jay's Avatar
Yeah, I'll probably do a boost leak test before I go back to the track
That's exactly what it felt like, some knock in 4th from the extra boost. Don't know if you have 91 or better in CO, but I can tell you 91 will knock on the rich stock fuel map, even from just a little extra boost. Hopefully the car will be dynoed soon, but dont know if I can dyno before and after the E-flash. I'll most likely dyno after the flash.
Also, I know the car seems weak, but if you look at other drag times posted by CA IX owners, my time is actully very, very good.
I might get a MBC down the road, but the boost control I'm working on is looking very promising. I modified the restrictors in the vaccum lines from the turbo, wastegate and solenoid. I seem to have complete control and a lot of room to up the boost (4 race gas).
