gt35r traps at 20psi and 92 oct
Old Sep 11, 2006 | 05:56 PM
JohnBradley's Avatar
Billy I'd be curious to see your .hex if you flash tune yourself. I am thinking that it most likely has the timing backed way off for higher boost in the higher load cells so you are losing power/torque because of that and nothing to do with the GT35.
For the record Phoenix, GT35's do end in XXXX as well. GT3575R, GT3582R are two that come to mind right off. Most people just dont use the extra nomenclature cause they dont know what mm wheel is in there.
Old Sep 11, 2006 | 06:25 PM
Turbojunkie's Avatar
I would if i knew anything about tuning or had a way id post it up. My flash was done by AL back in april when he came through. i did get the flash done on pump gas though. al was supposed to send me some info and and disk after he tuned it, but no go on that.
Old Sep 11, 2006 | 06:35 PM
PhoenixEvo's Avatar
My only mods so far r in my profile, but iam about to get a 50trim kit because i wanted good spool and pump gas #'s, However after seeing this i am thinking why would anyone get a 50 trim kit when they r trapping 122 on pump gas, stock block, pump gas, if this gt35r can trap 120 on pump gas but gains alot more then the 50trim on race gas. I know the 50trim should spool faster but once spooled on pump gas gas it looks to have the same output. What rpm do u hit full boost, wtq, and whp??? Any of this info will help thx
Old Sep 11, 2006 | 08:06 PM
LancerevoIX2006's Avatar
Originally Posted by PhoenixEvo
What gt35r kit is this??? Also what kinda traps were u expecting? The highest i ever heard or a gt35r trapping on pump gas is 121 by LancerevoIX2006 who just posted above saying his trap (yes i dont know if he has a gt35r, because his profile says "GTXXXXR", so maybe he has a 3076 or somthing but "35" doesnt take 4 x's). Besides that the highest traps i seen on a gt35r kit pump gas stock block is 118ish. Maybe just being a 9 and able to advance timing a bit more then an 8 is playing a factor.. or maybe just one of those other things like, humidity, head wind, heat soak, All these things could vary your traps. But what traps did u expect or hear from other 35r kits on pump gas stock block on an 8?
No my kit is a GT35RL i dont want people coming on evom and seeing that i have a 35R... yes i got a trap of 121 on 21 psi... my AFR's were weak that day... 10.80-11.20's and DEVO TUNING built my kit and i have a toatally stock block and no i didnt run my car on race gas hopefully we will go after i get some Hoosiers =D...
EDIT... STOCK ECU...
DEVO TUNING TWIN DISC...
STOCK SUSPENSION
I was only cutting 1.8 60''
shifting into 5th like a dumb*** at the end of the track =[
and i need to learn how to drive =D
Old Sep 11, 2006 | 09:56 PM
if you do a search under my screen name you should and old post with info on my kit. i get full 20 psi by 4200-4300 in 3-4. a little lagger in 1-2. i dont recall my exact pump whp.
Hiboost
Aug 11, 2009 10:06 AM
dustin03
Dec 10, 2008 10:56 PM
kouzman
Dec 4, 2008 07:15 AM
AlwaysinBoost
Oct 14, 2006 05:56 PM
DRAG
Apr 15, 2006 04:20 PM
