How did removing the factory 2-step affect your 60s?
Old Sep 20, 2006 | 06:49 AM
DRAG's Avatar
I'm just curious how your 60s changed when you removed the factory 2-step? I have been using it for a year simply because
1. I'm used to a 2-step on every car I have had.
2. it makes it really easy for impromtu stoplight races
3. it makes it easier on me for cutting consistent lights on the tree
4. it keeps me from shattering my transfer case
Without it, I need to set up and appointment with the car 20 seconds in advance to get a good launch
The best 60 I have been able to manage is a 1.77 on my Hankook snow tires, but I have only done that once and that was spinning out of the hole. I can consistently cut 1.82-1.84 but I usually bog. I have managed to squeeze 12.90 - 13.0 every time at the track even with my 1.84 60s (it is an 05 GSR with no mods and 3480 lbs. with me and no gas).
So I unhooked it to go to the track last night but the track closed because of the cool weather. I went out and did some launches on different types of surfaces. I tried 5000, 6000, and 7000 with a slight slip, and the car just blows the tires off in first leaving thick black marks for 20 feet. The rear steps right really hard and it feels like it is getting out of the hole HARD!
I'm just curious to see what some of your experiences are as far as improving your 60s without the factory 2-step. I am going to plug my computer up and just raise it to 6000 or 6500 after I try this.
Old Sep 20, 2006 | 08:38 AM
PessimiStick's Avatar
I believe Warrtalon and some others advocate for a 6k 2-step pretty strongly.
I haven't started to mess with mine yet, no dragging until next year for me.
Old Sep 20, 2006 | 02:56 PM
Warrtalon's Avatar
I did 3 runs with the 5k limiter still in place back when I first got the car and had no idea what it was. My 60's were 1.92, 2.4, 2.3 while scratching my head wondering wtf was keeping me from launching at 6k like I wanted to. That first run with the 1.92 was random luck that I even got off the line at all, and the result was a 13.17. The next two runs were 13.8-13.9 or so.
I came home and read up to find out that I could disconnect the switch, so I went back to the track, disconnected the switch, and hit a 1.76 60' en route to a 12.8@106.3, but this was with my old SAFC I that I had installed and tuned.
FYI, 3480lbs + 1.84 60' + stock does not equal 12.9 or even 13.0, so not sure how you're doing that.
Old Sep 20, 2006 | 05:05 PM
Evo_Jay's Avatar
Yes, but dont you use a reprogramed 2-step to launch?
Old Sep 20, 2006 | 07:51 PM
DRAG's Avatar
I'm not sure I ever understand any of your logic. I assume your logic is that since you can't do it, that someone else can't??? Honestly I get sick of you coming into every post and picking apart people's slow *** 1/4 mile times as if you have any clue WTF you are talking about. You will pick apart a 12 second time slip all day long over a stupid tenth of a second. Get a life dude. Whoever let you back on this site should be shot...you do nothing but argue anything that anyone posts.
I have run 12.9-13.0 at Indianapolis Raceway Park every Tuesday night all summer with 60s mostly in the 1.82-1.84 range, but I have managed to run 13.0 with 1.95 60s before at only 104 mph. My best ET was with a 1.77 60 foot, 8.2 @ 86 in the 1/8th, and 12.93 @ 102.9 in the 1/4. I supposed that isn't possible either right? Especially since you were only able to muster a 1.9 60 on your factory 2 step and I did 1.77 on my snow tires on the factory 2-step
To answer my own question I went to the track tonight and made three full passes. Here is the rundown from my first pass to the last:
60: 1.773
1/8: 8.234 @ 86.97
1/4: 12.887 @ 107.00
60: 1.805
1/8: 8.171 @ 87.72
1/4: 12.770 @ 107.93
60: 1.705
1/8: 8.104 @ 87.32
1/4: 12.739 @ 107.55
I suppose none of that is possible according to Warrtalon...so just to add insult to injury I'll add a few details about my 2005 GSR.
NO boost controller, NO flash, NO afc, $0 (read: ZERO DOLLARS) in power parts, 40 psi in my Hankook W300 Icebear tires, original air filter (ooo its dirty!!) and I still have a stock clutch line with the restrictor in place. Just to spice things up a bit...no I did not weigh 3480 when I ran these numbers tonight. Since I wasn't planning on heading to the track, I had a half tank of gas and my computer bag and golf clubs in the car with me...so with my 260lb fat *** I tubbed in at 3515. Not possible right?
I'm no superstar driver. I don't know any tricks. I don't full throttle shift, I granny shift. My first trip to the track when I bought my car was a 13.78 @ 98...hardly anything to write home about. I have just learned how to drive the car...thats all. Go ahead and tell me about how it can't be done because you didn't do it
Old Sep 20, 2006 | 08:00 PM
jrsimon27's Avatar
i do the same with my car i put more air in the tires 38psi and i do 7000rpm launches and i have done a best of 11.8sec but with a g-tech pro(not sure how accurate) and i aint got cams yet but this was with race gas and 24psi of boost!
Old Sep 20, 2006 | 08:11 PM
tripperfx3's Avatar
And let the games begin!!!! Anyways... Im not doubting any of you at all. Ive seen low 13's on stock evos all day long, but does the little extra torque and HP that the 05's have really make that much of a difference? Ive just got lightly modded 03 and I know its fast, but i just cant imagine it running low 13's. Im glad ya'll are and yet again i dont doubt it at all im geniunely curious about how the 05 VIII and the 06 IX run so much faster than lightly modded 03 and 04 VIII's. I know the MIVEC on the IX along with the slightly redesigned turbo do it, but with the 05's is it really that big of a difference over the 03's and 04's?
Old Sep 20, 2006 | 08:15 PM
jrsimon27's Avatar
ive seen videos from best motoring in japan where they drag race a stock evo 05model and they do 7600rpm launches and they dump the clutch the times they post are 12.7sec the 400m!
if your gonna do this you must have the restrictor pill in the clutch and you must use a lot of air in the tires to get wheelspin=saves drrivetrain!!
Old Sep 20, 2006 | 08:16 PM
jrsimon27's Avatar
its all in the launch
Old Sep 20, 2006 | 08:18 PM
DRAG's Avatar
I just get all hyped up when Warr posts because he never has anything positive to say...he just picks apart people's **** and it gets really old. This forum is here for us to share info and learn from each other, not to criticize and discredit people's accomplishments.
Old Sep 20, 2006 | 08:19 PM
jrsimon27's Avatar
60: 1.773
1/8: 8.234 @ 86.97
60: 1.805
1/8: 8.171 @ 87.72
60: 1.705
1/8: 8.104 @ 87.32
iam really glad you tried it out the car feels like a rocket when doing this
this is my car when it was stock i draged race against a modified sti and i did a 7000rpm kind of fast drop on my clutch check it out :http://www.youtube.com/watch?v=yJvomfRfwxk
Old Sep 20, 2006 | 08:25 PM
jrsimon27's Avatar
dont go against him we know he sounds very hard sometimes but he helps a lot of people in this forum and congrats on those times they are sick for a stock evo
Old Sep 20, 2006 | 09:33 PM
16ggst's Avatar
i like the 2 step.. my best at factory was a 1.80 after bumping it to 6k i pulled 1.70s stock clutch.
Old Sep 21, 2006 | 07:46 AM
11SECEVO's Avatar
Just Curious, i 'Though' that simply Un-plugging the Factory 2-step caused the ECU to Remove timing??
OH, and BIG CONGRATS on the 107mph!! Is this on a BONE STOCK '05??????? If so that's INCREDIBLE
Old Sep 21, 2006 | 07:58 AM
AlwaysinBoost's Avatar
60: 1.773
1/8: 8.234 @ 86.97
60: 1.805
1/8: 8.171 @ 87.72
60: 1.705
1/8: 8.104 @ 87.32
wow those times are really hard to believe from a FULL WEIGHT, BONE STOCK EVO. I'm not saying you didn't do it, just that its very hard to believe. There has to be something you aren't telling us. A bone stock EVO that traps 87 in the 1/8th and 107 on the big end with no weight reduction...
I pretty much trap high 85's consistantly and an occasional 86 in the 1/8th, never have I seen 87mph though. But I have a full TBE, 24psi spike, cone intake & o2 housing for mods...
If you are being 100% honest then your car is a freak of nature and you drive like John Force.
