Poke holes in "Wastegate actuator hose"??!!!
Old Oct 12, 2006 | 03:00 AM
smokedmustang's Avatar
Originally Posted by DragNRacing
The only time that I have heard of people putting pin holes in the hose is stock/restricted classes were boost controllers can't be used. Basically a way to cheat and get more boost...
Good info, thanks!
Old Nov 12, 2006 | 09:46 PM
lonestarion's Avatar
Talking
sounds like a honda owners idea.
most definatly swing your kicking leg back as far as you can
and kick the next person in the croch as hard as you possibly can
and as many times as you can b4 he hit the ground...
Old Nov 12, 2006 | 09:51 PM
tabio42's Avatar
If you buy a Dejon Tool MBC it comes with a straight hose adapter with a hole drilled in it for faster spool. Depending on the size of the hole it wont create a dangerous boost spike. But rather than put holes in hoses which can split and subsequently destroy the motor, you can buy a Dejon Tool.
Old Nov 12, 2006 | 09:54 PM
kimletrim's Avatar
Registered User
Ya beat me to it!
Old Nov 15, 2006 | 05:53 PM
C6C6CH3vo's Avatar
The typical MBC (forge, hallman) allready has a hole in it, it's called bleed port
Old Nov 17, 2006 | 02:04 PM
Jeff_Jeske's Avatar
When at the stip and filled with race gas I take the hose off the wastegate actuator.
Old Nov 17, 2006 | 02:09 PM
mac_05evo's Avatar
A local here at the strip unplugged his on his Honda for this "cheat" and blew his car up the next pass he made
Old Nov 17, 2006 | 02:34 PM
Jeff_Jeske's Avatar
Unplugging the boost source to the wastegate will allow the turbo to run absolute max boost. I see 27/28 peak boost but on straight 110 leaded fuel I can run the boost with no timing retard at 12:1 cleanly.
Old Nov 18, 2006 | 03:25 AM
ONRAILS's Avatar
Originally Posted by Soon2BEVO
Um no thats completely false. That would act as a boost leak and hurt response.
your an idiot. People need to stop commenting when they have no clue about something..
Yes it will cause added boost. Mazda uses such ****ty vacume lines that my MSP's vac likes dryrotted and my motor almost blew up but i suddenly noticed it was super fast and herd it knocking so i let out.
This is not a good way to add boost when mbc's cost less than 10$ to make.
Old Nov 18, 2006 | 06:59 AM
Soon2BEVO's Avatar
My bad I actually misread what the guy said. Dont have to get your panties in a bunch about it.
Old Nov 30, 2006 | 10:16 PM
TTP Engineering's Avatar
Adding a vacuum T of small enough diameter bleed port is how some accomplish additional boost.
Old Dec 7, 2006 | 08:42 PM
DarksideEng's Avatar
Also, if you take the vacuum line off of the wastegate, it will make low boost. About 12psi in our case. What are you all talking about??? It makes max pressure?? Am I missing something??
Old Dec 10, 2006 | 02:43 PM
justchil's Avatar
The WGA doesnt open the WG so max boost is made... If you have no mbc in place the WGA opens when the spring compresses (around 12psi on the stock WGA).
I've heard of this as a form of cheating is well
evil03
1180
Sep 21, 2021 10:31 PM
def1
Feb 2, 2017 10:34 AM
drb
53
Oct 25, 2016 07:50 AM
jsr426
78
Mar 30, 2009 12:03 PM
talon2evo
Mar 2, 2006 08:45 PM
