is this good
Old May 12, 2003 | 08:24 AM
jamie's Avatar
is this good
went to the 1/8 mile friday night it was about 90 degrees and about 95% humidity i hace a injen cold air intake cat back rrm headers. my first run reaction .180 60ft 2.482 330ft 7.051 1/8 mile at 10.924 63.83mph second and third run had launch problems ran a 11.289 and a 11.018 last run reaction was a .078 60ft 2.464 330ft 7.061 1/8th 10.947 mph 63.20 is that good for my mods? also had 1/4 tank of gas my best times was when i dropped the clutch from about 3500rpms alot of wheel spin but i didn't bog. it seems like i get better traction on the street. stock rims and tires. please give advice for better times thanks for the input.
Old May 12, 2003 | 10:10 AM
jamie's Avatar
any feedback?
Old May 12, 2003 | 01:18 PM
jamie's Avatar
i would like somebody to respond anybody good bad it doesn't matter
Old May 12, 2003 | 01:24 PM
Guru_Del's Avatar
i cannot comment on times but you will get better traction on streets vs track. if you are gonna run track alot get a different set of tires for better grip.
Old May 12, 2003 | 01:37 PM
jamie's Avatar
should i go with a lower profile tire that would probably help get off the line a little better. softer the better?
Old May 12, 2003 | 01:43 PM
rhyzin's Avatar
you can go softer for more grip, but they just won't last as long. you're really just looking for a tire with grip. i'm leaning towards getting the yokohama AVS ES100's or the Dunlop SP Sport 5000. i'm sure it'll help, but nothing (really) beats driving technique.
Old May 12, 2003 | 01:51 PM
jamie's Avatar
i might try to slip the clutch next time just don't want to burn it up. i raced a a wheel drive eclipse he ran a 9.5 at 79.97 i was with him till i hit second then he was gone. most of the civics that were modded about the same ran mid 11's or slower. evo only ran a 9.22 on the 1/8 that was on his fourth try he had major launch problems. most of subies ran about 9.5 . maybe it is the heat and humidity causing the slower times.
vikevo9
Nov 15, 2008 02:19 PM
evil_eagle
Oct 11, 2008 08:20 PM
MikeMAN
Jul 20, 2008 06:03 PM
GsXiNuOFF
May 15, 2008 05:34 AM
blitzbaster
Sep 25, 2003 12:55 PM
