someone help me understand.... 11.8 @119mph??
Old Oct 26, 2006 | 06:20 PM
  #46
boostedwrx's Avatar
Why is everyone tripping? It's on 100 octane.
Old Oct 26, 2006 | 07:57 PM
  #47
A418t81's Avatar
29 mph on the backside is wild. I was proud of my 35R on pump and 20-21 psi gaining 26.
Old Oct 26, 2006 | 08:00 PM
  #48
Warrtalon's Avatar
Oh, you think it's normal for stock VIII turbos to trap 119 on 100oct? Haha, don't we all wish it was that easy!! Even with 100oct, these are absurd trap speeds for only 22psi. I have never heard of nor seen nor dreamed of a stock turbo'd Evo trapping that high on 22psi. It just doesn't make sense, similar to how it makes no sense to gain 16whp from a 1psi gain on the stock turbo. It simply cannot flow enough air to gain power like that when it's already at the limit of its efficiency and flow capacity. So, there is no explanation to why this car is so fast, but it is certainly IS fast. It's pretty amazing - I just wish we knew what was causing it.
cbrtrx, why did you mention that you gain 28mph in the back half without mentioning that it's because you run nitrous? That was a pretty lame thing to do.
Old Oct 26, 2006 | 08:04 PM
  #49
vwjeff's Avatar
your times look almost identical to mine...
R/T .095
60' 1.759
330 5.045
1/8 7.730
mph 93.69
1000 9.977
1/4 11.883
mph 118.76
Old Oct 26, 2006 | 08:23 PM
  #50
saywhen's Avatar
^^ no......he is gaining 4 mph faster then you in the back half. That is a huge difference.
Old Oct 26, 2006 | 10:44 PM
  #51
Warrtalon's Avatar
Actually, Jeff's splits point to the thread originator's splits being even more suspect. Notice how Jeff is slower to the 60', 330', and 660', but then he gets to the 1/4 at the same time with a lower trap speed. These two 5 spds have different gearing, though. I'm actually wondering how Jeff managed to trap nearly 119 on the IX 5spd when 4th gear is so short. 119 is well past the stock rev limiter and even beyond the normal Dynoflash rev limit (7800).
Old Oct 26, 2006 | 11:30 PM
  #52
willum14pb's Avatar
I know of someone that can solve this mystery! Call the Harly boys! (If you watched South Park recently you'd know .. and yes I know Harly is not what the original name is)
Old Oct 26, 2006 | 11:43 PM
  #53
cbrtrx's Avatar
yes my car uses nitrous, even with out it my almost stock car picks up a steady 25mph gain on the back half, i think it has to do with either his shifting or his air fuel, nitrous cars are known for falling off in the top end, this is my 4th car i have owned with nitrous and they all are much stronger in the 1/8 then in the 1/4, i was very surprised to see my evo pick up 29 mph on the back half
Old Oct 26, 2006 | 11:48 PM
  #54
Warrtalon's Avatar
You only gain 25 in the back half on a nearly stock Evo if you're weak on the front 1/8th. There's no reason for you to be surprised about having huge gains in the back half with nitrous. The nitrous is doing all the work. Your car without nitrous is nothing special.
Old Oct 26, 2006 | 11:57 PM
  #55
RazorLab's Avatar
Originally Posted by jbfoco
The car feels really good, i cant wait for thunder hill 11/17
I'll see you there, what group are you in?
Old Oct 27, 2006 | 01:28 AM
  #56
SKILMATIC's Avatar
The point is it is improbable to make those numbers with the list he gave us. I think there is something more to the puzzle, or the boost is actually more than he thinks.
Let me give you a comparison, my turbo(sc61) on pump gas @ 22psi made around 400whp. So how could a turbo much more smaller than mine put out similar numbers? Catch my drift? Like I said it is improbable.
Old Oct 27, 2006 | 05:41 AM
  #57
vwjeff's Avatar
I used all 5.
Old Oct 27, 2006 | 05:53 AM
  #58
vwjeff's Avatar
No I have 4 on him in the back half... read it again
Old Oct 27, 2006 | 06:19 AM
  #59
Smike's Avatar
vwjeff you gain 25.07 (118.76-93.69) from the 1/8 to the 1/4
he gains 28.98 (119.02-90.04) from the 1/8 to the 1/4
28.98-25.07 = 3.91 in his favor on the back half. He is making up that 3 mph (you have on the front half) you have on him at the 1/8.
Besides, your gearing is different, turbo is different, you have mivec, and can run more boost on 93 oct than the VIII. So comparing to a VIII just isnt the same.
On a side note: now Im really thinking I should get some cams for my car. I run 115.96 on 100 oct with 25 peak - 22 at 7k (at least thats what I ran last time with my leaking hg ). Cams would be good for another 20-30whp right? Might pick up a few (1-2) mph there...tempting...very tempting...
Old Oct 27, 2006 | 07:17 AM
  #60
vwjeff's Avatar
Oh you guys are talking about the back half meaning the last 1/8th and not the first
