What the hell is wrong with my car?
Went back to the track last friday cause it was cooler low 70s upper 60s and the car ran slower than 3 weeks ago when it was blazing hot!! WTF!!! I dont know what is wrong with it....I got a good 1/8 but the car has no top end!!! Then again i pulled a IX by a car lenght saturday night and he has the same mods i got.. I even pulled another IX also yesterday that has more mods than me and hes one hell of a driver!! Heres my times... The only thing that i can think of its a boost leak or the car may be pulling timing on the top end
First run
r/t: .341
60':1.789
330:5.251
1/8:8.135
mph:84.83
1000:10.628
1/4:12.726
mph:107.23
Second run
r/t: .778
60':1.815
330:5.216
1/8:8.076
mph:85.63
1000:10.567
1/4:12.650
mph:105.17 <---Look at the mph
Third run
r/t: ..801
60':1.768
330:5.161
1/8:8.000
mph:86.62
1000:10.482
1/4:12.570
mph:104.69<-----Again look at the low mph!
First run
r/t: .341
60':1.789
330:5.251
1/8:8.135
mph:84.83
1000:10.628
1/4:12.726
mph:107.23
Second run
r/t: .778
60':1.815
330:5.216
1/8:8.076
mph:85.63
1000:10.567
1/4:12.650
Third run
r/t: ..801
60':1.768
330:5.161
1/8:8.000
mph:86.62
1000:10.482
1/4:12.570
Originally Posted by Jasil
Looks like it's pulling timing to me. 19mph on the backhalf is less than stock for crying out loud. Check the tune IMO.
well I can tell by your short times that the shifting needs work, but thats not telling the whole story as to why your car is seriously slow up top.
First off do a boost leak test up to 24-25psi. If your still running that stock BOV I'd bet thats one of your major leaks.
Did you log your runs? Was any timing being pulled? If you had zero knock you should be able to add a couple of degrees from 5500 up until you start to knock in 4th gear.
you have to go by your times at the track. you said your car seemed faster before the clutch was installed and your times were much better before your clutch?so maybe something is wrong how much boost were you runnin?correct me if i am wrong?
I also wana add that after the first run that i trapped 107, someone later had spun out and they were cleaning the lane for more than 1 hour... I wonder if that had effected my times as the track not being prepped correctly since all my pases where on that same lane??
Originally Posted by eve-slow
Do you think you could have had a bad batch of gas in the last couple of weeks?
Was there any wind? Sorry I have to ask cause wind killed me one day at the track this year. If you cant log your runs try throwing some race gas in and running. That should prevent timing from being pulled if thats the problem.
