Evo Vs Cobra????
Old Feb 5, 2007 | 09:30 AM
  #31
IX stealth MR's Avatar
Iv done this exact race about 10 times, this is what happens.
A bone stock Evo 9 MR Vs. 03/04 Cobra intake, exhaust. From a 25 or 45 roll, the Cobra will pull 2-4 lengths by 120.
A Evo 9 MR with, TBE, Intake, @21psi, tune Vs. 03/04 Cobra with intake, exhaust. From 25 or 45, the Evo will pull 2-3 cars by 120.
A 03/04 with a ported blower, running 2-3 more psi than stock & tuned will pull 3-4 + lengths in a 25-130 roll
Old Feb 5, 2007 | 09:31 AM
  #32
evilevo2006's Avatar
ok lots to here answer so
yes i am tunned
i run 93 oct on 23 psi
no he does not have a pulley but that can change if he gets one and does not tell me.
i cant get race gas. so can i run 100oct and turn the boost up a psi or 2??? do i need a return over my current tune that i have or no
Old Feb 5, 2007 | 09:37 AM
  #33
boostinjuice's Avatar
first of all.. you should get cams..
second of all.. circle track? where are you racing to get up to 130mph? must be a long track?
Old Feb 5, 2007 | 09:45 AM
  #34
KOEvo's Avatar
yes i am tunned
100 octane is "race gas." You don't need a new tune, though one would optimize the situation (not by much, but it wouldn't hurt, maybe 10 whp at most). Just add the 100 octane and turn it up to 27psi on an VIII turbo w/ 10.5 hotside or 29psi on a IX turbo. Datalog if you can, see if you're knocking at all; if so take it down a couple psi accordingly...
For reference when i had my stock 2005 turbo and added 100 octane i turned up boost to 25 psi and wasn't knocking, so i turned it up to 27 psi and still didn't get any knock counts, but at that point i knew the turbo was out of its' efficiency range. On 93 octane i was getting knock counts as high as 8 in 4th; so as you can see, 100 oct. gives you quite a big buffer.
Old Feb 5, 2007 | 09:47 AM
  #35
Originally Posted by KOEvo
100 octane is "race gas." You don't need a new tune, though one would optimize the situation (not by much, but it wouldn't hurt, maybe 10 whp at most). Just add the 100 octane and turn it up to 27psi on an VIII turbo w/ 10.5 or 29psi on a IX turbo. Datalog if you can, see if you're knocking at all...
o sorry i thouht race gas was like 116oct.
im on an 8 turbo with ported 10.5 hotside. i have a wideband and egt gauge plus i can data log. so i will fill it up with 100oct see if i can get a flash for it and do some logs.
Old Feb 5, 2007 | 09:51 AM
  #36
KOEvo's Avatar
Yup, you got it about right. But remember, you don't HAVE to get a new tune, i never did when i ran 100 octane and 27 psi w/ no knock counts.
..Just means i left some power on the table.
Old Feb 5, 2007 | 09:53 AM
  #37
im tuned buy your tuner as well. great guy btw. ok i will take it from there and see how it go's.
  #38
Warrtalon's Avatar
Originally Posted by hamflex
Are you able to run 93 octane or are you restricted to 91. I wouldnt run race gas and increased boost with out a tune. If you are still on stock tune, chances are your car will be slower.
Bah, hate when people do this.
Running some race gas and raising the boost will work like a charm. We're talking 20-40whp depending on where the boost is currently. You don't have to get retuned just to add race gas and raise boost.
Old Feb 5, 2007 | 09:57 AM
  #39
ok well like i said im on 93 oct and i run 23 psi now.
even though a retune or reflash is not needed as you say i would think it would help though but is not needed.
what is your opinion on raising the boost upto.
Old Feb 5, 2007 | 10:04 AM
  #40
Warrtalon's Avatar
There really is no boost limit on the stock turbo when on race gas. Run whatever boost you're comfortable with...
  #41
hamflex's Avatar
Cams my friend, CAMS. If you can get some cash together in time i would invest. And befor you do the pulls.......Make sure you are the one doing the honking to initate that race. Each time you do it at every mph, 20,40, and so on. Get to the desired mph and just roll there for a bit let that roots blower get as heat soaked as possible. Because its proven! dyno run after dyno run, roots type super charged cars lose power run after run because they get so damn hot. So do this and hopefully it will help a bit. Especially if you do all the roll races in a row!!
  #42
Jasil's Avatar
Not putting a pulley on a cobra is like not putting a MBC on a EVO he is missing out on big HP for practically nothing
Old Feb 5, 2007 | 10:10 AM
  #43
hamflex's Avatar
For a guy who acts like he knows everything I hope thats your unpleasent sarcasim.
Efficeint power is not made on whatever boost you want. Especially if you are only running 100 octane. Listen to KOevo, sounds like he knows whats up when it comes to 100 octane and boost settings.
Old Feb 5, 2007 | 10:13 AM
  #44
4WS Tuning's Avatar
i got ripped by a cobra with similiar mods, pulley and a 50 shot... he pulled me about 4 cars from a 20ish roll.
from a dig we were even til 100
if u really wanna know if you have a chance go on the cobra forums and do some research. we own evos, we know what your car is capable of. not his.
cheers!
Old Feb 5, 2007 | 10:14 AM
  #45
neather of us are doing the beeping. his old man will have the hemi pickup in the middle of us and he will beep snce it is on a track then we dont have to worry about who jumped who plus we have 3 hours of fun so time is good
