2 step
Old Apr 7, 2007 | 10:10 PM
evovin's Avatar
2 step
my stationary is set @ 5000rpm. but it still bogs down to about 3400rpm when i launch! what should i do?
Old Apr 7, 2007 | 10:14 PM
llabmik2's Avatar
Well you can flash you ECU or you can just learn to launch better. I went off the stock limiter for about 3 months before i flashed. I only bogged it a couple times its all about how you launch.
Old Apr 7, 2007 | 10:18 PM
evovin's Avatar
dont you think i should set it higher?
Old Apr 7, 2007 | 10:32 PM
Clutchdc5's Avatar
set it higher, launch it off the 2step, mines at 6100
Old Apr 8, 2007 | 05:41 AM
05WhiteEVO8's Avatar
mines at 5800 hundred, just depends on how YOU drive.
Old Apr 8, 2007 | 01:27 PM
2003evo8's Avatar
set it higher, i think last time i checked i have mine set at 6000 rpm or so
Old Apr 8, 2007 | 01:39 PM
dsmfan95's Avatar
Slip the clutch more.
Old Apr 9, 2007 | 07:51 PM
evo_what's Avatar
if your launching technique is to drop the clutch more than slipping it, then you must raise the 2step. of course it risks your tranny more. if i were you i'd slip the clutch more and keep the 2step at 5000rpm. its better to wear your clutch than to break your tranny
-Chris
Old Apr 9, 2007 | 07:58 PM
Smike's Avatar
https://www.evolutionm.net/forums/sh...75&postcount=4
All depends on the driver...er and the car, and the tire pressure, and the track....but 5k should get you some low 60s
Old Apr 9, 2007 | 08:05 PM
GHEvo8's Avatar
i never had any luck on the stock setting at 5000, i just reved and sliped, try that, but once i raised it i havent had a problem since
