Burn out?? Prepare for the track
Old Jul 30, 2007 | 10:25 AM
Forrest Gump 9's Avatar
Hi guys
Just trying to prepare for the track this Wednesday. Do we need to do the burn out on the Evo? If not, do I just drive around the water box and up to the line? Thanks in advance.
Old Jul 30, 2007 | 10:29 AM
ak47po's Avatar
Life is like a box of chocolates.
Old Jul 30, 2007 | 10:30 AM
AutobonEvo's Avatar
you do realize you have AWD right? I would just go around the water box....do your tcase a favor.
Old Jul 30, 2007 | 10:33 AM
jenx1976's Avatar
How the hell are you planning on doing a burnout on the evo?????anywyas,i read an article somewhere that burning out on street tires are actually bad., makes the tires britle and less grippy. its diffrent on race tires, helps them wrm up.
Old Jul 30, 2007 | 10:36 AM
Thanks, just to make sure.
I used to have a GMC Typhoon, and with that we do a little quick burn out just to clean up the tires. The drive train on that thing also a little beefier. Thanks again.
Old Jul 30, 2007 | 10:40 AM
r.m.s.'s Avatar
he he he he
I believe you got your answer, so I guess all there is left to say is good luck have fun.
That was funny though.
Old Jul 30, 2007 | 11:19 AM
PWevo's Avatar
I think I read the same article. Worthless to burnout unless you have race tires.
Old Jul 31, 2007 | 05:47 PM
ant_turbo's Avatar
Yes you can I have spun the front tires!! I'm making 360hp 100/octane(20psi tire press) ,, And before I stage I do a quick launch..And you get a lil spin right before they hook,,Here check out my launch
http://videos.streetfire.net/video/c...7c003ce700.htm
Old Jul 31, 2007 | 08:40 PM
RobDogg's Avatar
Yep you can... here in S.D. a guy does a mini burn out with his Ra-1s at Qualcomm all the time... intimidating as all hell when your driving around the water on the other side...
Old Jul 31, 2007 | 09:20 PM
Paul Nelson's Avatar
Ive always done a 4 wheel burnout but im on slicks
Old Aug 1, 2007 | 08:43 PM
SteelEvo's Avatar
i do a mini one to clean off the sand from the return lane/street
Old Aug 3, 2007 | 08:48 PM
jamerin's Avatar
i just bought a set of bfg drag radials....so is it better to drive through the water box and do mini burn out or go around and stage for the light..... by the way i'm running on shep trans and beef up t case.......
Old Aug 3, 2007 | 10:47 PM
jamerin's Avatar
bump
Old Aug 4, 2007 | 04:40 AM
mcwop23's Avatar
on street tires try to avoid the water box, on drag radials or slicks do a little burnout. I only race in one lane at gainesville raceway because only one lane can avoid the box.
Old Aug 4, 2007 | 05:21 AM
TxEvo8's Avatar
Is this guy drag racing on Ra-1's? I can't imagine that would provide much grip at all. It usually takes a few laps around a road course for me to get them up to temperature. They are worse than street tires until the get hot...
