Top 10 Fastest/Quickest – Evo Green/ 20G-LT
Old Nov 1, 2007 | 12:43 PM
dudical26's Avatar
Originally Posted by smp3000
I seriously can't wait to start, it will take a while, but it'll be done right. Does anyone have any pics of the Green next to a stocker? I'd love to see the size difference.
If I am not mistaken they would look exactly the same. The only difference is the wheel on the cold side. The inside of the cold side housing is also machined a bit to allow the wheel to fit. But as fas as the housings go, they are the same as stock.
Old Nov 1, 2007 | 12:44 PM
dudical26's Avatar
Originally Posted by 9sec9
I could be wrong, but it's my understanding that it was NOT full interior. I think most of the EVO community understands the difference between the term 'race prepped' and stock appearing. I would say when someone takes the time to begin cutting all bolts on the car that extend beyond the nuts and all interior pieces are removed and a normal stock car weighing 3200+ now weighs 2800 lbs or less and the engine is built (not stock) and it's running an AEM with C16 and slicks, it could be considered race prepped as opposed to stock. I don't think Curt would even question that fact, as a matter of fact, I'm sure of it. The only thing he would point out is the fact that he didn't fully take the time to tune the 20G-LT setup to it's maximum potential on his car. Those were his words when I spoke with him.
Has Curt really ground off the excess of bolts on the car? I know that it saves a surprising amount of weight but its a ton of work.
Old Nov 1, 2007 | 01:31 PM
9sec9's Avatar
Turbine side is cut for the larger wheel.
Old Nov 4, 2007 | 09:02 PM
DragNRacing's Avatar
DragNRacing / 4-21-07 / Evo VIII / 6sp, stock block & head / E85
Best ET: 11.147
Best MPH: 126mph
Old Nov 5, 2007 | 07:19 AM
dudical26's Avatar
Best ET: 11.147
Best MPH: 126mph
updated. Thanks for following the format
Old Nov 5, 2007 | 07:32 AM
Boltz.'s Avatar
FCOTM Winner
Nice thread.
Old Nov 5, 2007 | 05:12 PM
Your welcome. Please bump me up to 5th on the ET list though as 11.147 comes before 11.15.
Thanks
Old Nov 5, 2007 | 05:22 PM
dudical26's Avatar
Thanks
Duhh.... Woops.
Old Nov 6, 2007 | 07:37 AM
9sec9's Avatar
Sorry dudical26, I didn't realize that OKIX had run a 127.98 during the shootout. I thought that the et/mph needed to be during the same run. Here's the list of the runs. Top row is the 127.98. It won't change position any, but just needed to be corrected. Thanks
Old Nov 6, 2007 | 04:28 PM
dudical26's Avatar
changed.
Old Nov 9, 2007 | 03:08 PM
Duby's Avatar
any 93pump+meth times ?? anyone ??
Old Nov 11, 2007 | 04:14 AM
Deepseadiver's Avatar
1. Curt Brown / Unknown / Evo VIII / AEM, Fully Lightened Race Prepped Car / C16 / 10.58
2. OKIX / 10-13-07 / 2006 Evo 9 / Stock ECU w/o nitrous / VP Import + Meth / 10.87
3. David Buschur / Unknown / Evo VIII / AEM, Daily Driven / C16 / 10.88
4. Dadriva / 5-7-07 / Some Weight Reduction / C16 / 10.92
5. DragNRacing / 4-21-07 / Evo VIII / 6sp, stock block & head / E85 / 11.147
6. Eric / 5-7-07 / Unknown / Unknown / 11.15
7. freddy302 / 9-14-07 / 2003 Evo 8 / Stock ECU, 100 lbs above regular evo8 / C16 + Meth / 11.230
8. Deepseadiver/ 09NOV07/ 06 Evo IX SE/ Stock ECU, block & head/ 91+meth/ 12.5
Old Nov 11, 2007 | 11:02 AM
SPIN2GST's Avatar
Eric aka SPIN2GST / 10-13-2007 / Evo VIII / 5spd, stock block & head / E85 / Kumho MX 255/40 17/ Only weight reduction, spare tire, jack & tools, front bumper beam removed .
Best ET: 11.06
Best MPH: 128.7mph
Old Nov 11, 2007 | 01:19 PM
dudical26's Avatar
8. Deepseadiver/ 09NOV07/ 06 Evo IX SE/ Stock ECU+meth/ 12.5
What was your speed?
Old Nov 11, 2007 | 04:00 PM
It was Firday night races, so no time slips. They were just anouncing the times.
It was 80 degrees and 80% humidity out side. I am positive I had a ****ty 60' foot time. I was on stock rubber at 35 PSI and spinng most of first gear. I bet the trap speed was pretty good, but have no idea.
That was my second time ever running at the drag strip, and am still learning. Also everyone says add a full second to you state side time and that is what you'll run here, because of the temp and track conditions. So I am thinking I did not do too bad.
Next time I'll put on my R-compounds and lower the PSI. I hope to break into the 11's.
