Bouncing off limiter in 4th!
Old Nov 4, 2007 | 04:58 PM
LITE SPD's Avatar
Today at the track, my brother and I wanted to test the new setup on his Evo IX. But we ran into a problem. His limiter is set at like 7800 rpm and the car was bouncing off of it in 4th gear for the last 50-60 yards making his trap speed only 116.5mph.
I know the only way we can really fix this is to raise the rev limit, but the motor itself is basically stock (outside of GSC S1 cams) and we don't want to run into and engine failure in the future. Or are we being too conservative? Can we rev it out to 8000 RPM without issues? He doesn't road race the car or anything like that. Its just a daily driven Evo that once in a great while will see a drag strip.
Which raises another good question, how far do we go for that great time slip? Will raising the rev limiter, going with taller tires, changing gear ratios really make the car any faster on the street? Or will it only show good track times?
Old Nov 4, 2007 | 05:00 PM
EvoDan2004's Avatar
i cross the line a t 8300rpm. i have bone stock block but i have supertech dual valve springs. raise the limiter bro. you will be fine.
Old Nov 4, 2007 | 05:01 PM
ImprezvSE's Avatar
I raised the rev limit to my 9 to 8200. I shift at 8k in 1st to 3rd and rev out 4th. I still hit the rev limiter through the traps but now its at 125mph
BTW the only thing I put in the motor was cams all else is stock.
Old Nov 4, 2007 | 05:06 PM
neweraevo8's Avatar
What was your times?
Old Nov 4, 2007 | 05:07 PM
EvoDan2004's Avatar
mine?? 11.2 at 126.56mph 1.70 60 foot
Old Nov 5, 2007 | 01:13 PM
Duh Panda's Avatar
nice raise that limiter up to 8100
Old Nov 5, 2007 | 01:58 PM
dsmjeffro's Avatar
I As Well Hit Rev Limit @ 118 Going Through The Traps My Limiter Is @ 8100
Old Nov 5, 2007 | 05:41 PM
StreetThisEvo's Avatar
8000 rpm is fine IMO on the stock valvetrain. I had to rev mine out till I got the Evo 8 fourth gear installed.
Old Nov 5, 2007 | 05:50 PM
joosdawg's Avatar
8300 here on all stock valvetrain with hks 280 cams no problems
Old Nov 6, 2007 | 02:01 AM
Tpayne84's Avatar
Usually at what mph do you have to shift into 5th at? i havent gone down the track on my new setup yet so i dont know what im going to be trapping.
Old Nov 6, 2007 | 09:41 PM
EVIL_EVO_VIII's Avatar
Get a taller tire, that will help alot
Old Nov 7, 2007 | 01:15 PM
gamebred26's Avatar
how are you guys trapping so high on the 9 in 4th?
Old Nov 7, 2007 | 01:16 PM
gamebred26's Avatar
in an Evo 9?
Does mph in a certain gear increase with hp? I thought it didn't...
i am trapping 112 now and there isn't much rpm left...
Old Nov 7, 2007 | 07:21 PM
ImprezvSE's Avatar
The stock clutch was a huge factor for me in mph. Get a clutch and it will help your mph. The stock clutch was hurting my hp and my trap speed from sliping.
Old Nov 7, 2007 | 07:58 PM
596736's Avatar
What is the general cost installing an evo VIII 4th in the tranny?
