Fastest Strokers
Piston skirt wear isn't an issue if it's given the proper clearance and you use a quality piston.
As for revs, why spin it to 9k when you can make more power at a lower RPM with more torque and faster spool? What I'm trying to say is that not being able to rev it to 9 grand is a moot point given the lower power band.
Why not spin it to 9 grand? If you only spin it to 8k then you will need a bigger tire under the car to go the same speed.... Most people making this kind of power are trapping around 140 or so and dont want to shift into 5th gear.
I also am not a fan of strokers for drag racing.
-Em
Well you and I are on 4G64 block so I'm not sure either of us classify as strokers. An actual 4G63 stroker I thought was a bit iffy over 8k.
