Capitol Raceway
Old Mar 2, 2008 | 03:49 PM
vaboostn33's Avatar
Capitol Raceway
Just got back from Capitol. First time for me at that track. Only got 2 runs in but pretty please with how I ran today for whats on the car, or should I say whats NOT on the car.
My second run I missed 4th.
All I have done to the car is a full TBE, and IC pipes. And I had mike give me a 2step and eliminate the boost cut last night. On 20psi.
First run:
R/T .784
60' 1.77
1/8 8.071
MPH 86.99
1000 10.552
1/4 12.636
MPH 108.89
Second run:
R/T .673
60' 1.726
1/8 7.928
MPH 86.46
1000 10.474
1/4 12.586
MPH 107.99
EDIT: CAR IS NOT TUNED!
EDIT #2- this is not my RS, this is my flat black 04.
Old Mar 2, 2008 | 04:44 PM
Warrtalon's Avatar
An 04 on pump gas, no tune, and stock boost would not trap that high under any circumstance, so my guess is it's more than 20psi.
Old Mar 2, 2008 | 04:45 PM
vaboostn33's Avatar
its an 05 turbo. and it is 20-20.5 psi holding.
Old Mar 2, 2008 | 04:49 PM
Warrtalon's Avatar
It can't "hold" that much boost unless the boost system is modified or the "non-tune" also includes modified boost tables. Sorry, but the stock boost system hits a PEAK of 19.5 psi and tapers to 16psi, so "holding" 20-20.5psi is not possible unless something has been changed.
Also, having a different turbo is a mod...
Old Mar 2, 2008 | 04:53 PM
vaboostn33's Avatar
Well then Mike must have done something else when he was messing with it last night. He said he couldnt do much because my ECU was locked. and yes you would be correct, it is a mod, i also forgot i had a ported and polished ex. manifold. and a mbc which is why i was running 20.
Old Mar 2, 2008 | 05:03 PM
Warrtalon's Avatar
You forgot...ok.
Old Mar 2, 2008 | 05:11 PM
vaboostn33's Avatar
Yes i forgot. It came with the car so its not something I remember when I name what Iv done. And the mbc becuase i said it was at 20, kinda speaks for itself.
Old Mar 2, 2008 | 05:22 PM
Warrtalon's Avatar
Uh huh. You seemed pretty sure of what the car has...or does NOT have...and you sounded pretty proud of it.
"Only got 2 runs in but pretty please with how I ran today for whats on the car, or should I say whats NOT on the car. All I have done to the car is a full TBE, and IC pipes. CAR IS NOT TUNED!"
So, we went from:
- TBE
- IC pipes
To:
- TBE
- IC Pipes
- Ported/polished exhaust manifold
- 10.5 hotside
- MBC
- 90% chance it actually is tuned
Old Mar 2, 2008 | 05:36 PM
vaboostn33's Avatar
ok. ill have you proof read my next post. and like i just said, the ECU was locked so I couldnt get it tuned, and when I said the boost was set at 20, hmmm, never mind, i dont even feel like getting into this **** again. I posted my times, that was the point of the thread.
Old Mar 2, 2008 | 05:41 PM
SPEED's Avatar
So, we went from:
- TBE
- IC pipes
To:
- TBE
- IC Pipes
- 10.5 hotside
- MBC
Old Mar 2, 2008 | 05:54 PM
Warrtalon's Avatar
If it's locked, then it's tuned. It doesn't get locked randomly.
The point of the thread was your times and that you accomplished them with so few mods - that's why you kept pointing it out and even used ALL CAPS to say it was not tuned when it actually is tuned.
There's nothing to get into with me. You lied, you got punked, and now you're pretending like you "forgot" more than half your mods.
For all the mods listed, the times and traps are "ok." Good job.
Pr3z
Oct 16, 2007 07:06 AM
Hmoneybagz
Aug 26, 2007 12:40 PM
EVIL_EVO_VIII
Nov 15, 2006 09:12 AM
lawdogg
Dec 3, 2005 12:41 PM
Rollaway
Dec 24, 2003 04:52 AM
