0-60
Old Apr 15, 2008 | 08:14 AM
chrisbiltoc's Avatar
0-60
I know you can use a smaller turbo and get a quicker 0-60 or use a bigger one that gives more top end. So my question is what is an ideal setup for geat 0-60 time? I have searched and seen a few but most people go for overall power or top end. Thanks for the input.
Old Apr 15, 2008 | 08:27 AM
EvolNinja's Avatar
I think even with your stock turbo, a good tune can get you quicker 0-60 but it depends on the mods you put into your engine too. I haven't test mine yet bc I haven't finish with the tune yet.
Old Apr 15, 2008 | 08:37 AM
05ah8james's Avatar
Heres what ypu're lookin for!
Old Apr 15, 2008 | 08:38 AM
Mr. Evo IX's Avatar
Well the FQ400 has a 3.x 0-60 with a ~35R sized turbo so I'm not sure the smaller turbo logic is correct.
Old Apr 15, 2008 | 08:52 AM
Maybe but im sure it has more boost and different support then a regular 8. Right? Im not to familiar with the FQ's. What would you suggest?
Old Apr 15, 2008 | 08:53 AM
TeStUdO's Avatar
My question is, why do you care so much about 0-60? Change the gearing in the transmission if you want a fast 0-60 so bad.
Old Apr 15, 2008 | 08:58 AM
It is just a general question that I was curious about. If you dont like the question then dont post and move along. Thanks.
Old Apr 15, 2008 | 09:01 AM
TeStUdO's Avatar
I told you what to do to get the "ideal" 0-60 time. It doesn't really matter about the turbo size, because you can just run anti lag and dump a ton of timing to build a bunch of boost to launch off the line with.
Old Apr 15, 2008 | 09:04 AM
Yeah and thanks. I was just answering yours.
Old Apr 15, 2008 | 09:29 AM
UCB's Avatar
UCB
stock turbo +meth+race gas running 30psi should do the trick
Old Apr 15, 2008 | 11:22 AM
Mr. Evo IX's Avatar
0-60 performance is very relevant to overall performance and general drivability. This is the most common operating range of a street car.
The Evo is capable of 60mph in the top of second gear, what type of gearing changes would result in better 0-60? Taller first gear?
I agree with a previous poster, the optimal pump gas / meth street warrior would probably look like a FP Green car with Meth @ 30psi. Or Full Race's twin scroll 30R setup.
Old Apr 19, 2008 | 06:30 PM
evokel's Avatar
whats that? like a 10.8 sixty foot. lol
Old Apr 23, 2008 | 07:44 PM
saywhen's Avatar
race map or meth with a twin disc, good launch and a stock turbo up to a moderate turbo is going to be really fast. I think the clutch and launch technique are more important then anything else. I don't think you can change the gearing much as you don't want to shift twice. I've always wondered what my 0-60 time is when doing the 1/4 drags. I have had a 1.6 60' with a 9.5 to 92mph in the 1/8. My quess is that 60 came in around 4 seconds.
Old May 3, 2008 | 05:27 AM
recompile's Avatar
My Beltronics Accellerometer put my 11.8 run @ 120mph at 0-60 in 3.24 seconds with a 1.75 60'
Old May 3, 2008 | 06:54 PM
SHhhhh's Avatar
http://s2nd.com/convert-eighth-mile-...ty-calculator/
