Tilton Owners Please Help
Old Jul 11, 2008 | 11:56 PM
raiceboi697's Avatar
I have a tilton cerametalic clutch in my evo and i cant seem to launch the thing right, if i just dump it i get the obvious wheel jump, and if i try to just ease it out i have crappy 60' times..please someone help me, going from mid 12s to 14s is horriable
Old Jul 12, 2008 | 10:46 AM
2.3 Evo 8's Avatar
Need more info!
What kind of tires?
Tire pressure?
Suspension?
How are you launching it? What rpm?
Old Jul 12, 2008 | 11:25 AM
Liqquid's Avatar
poly motor mounts will help stop this, esp. the front and rear mount. Also, wheelhop can be eliminated by adjusting the rpm you launch at combined with the right tire pressure.
Old Jul 12, 2008 | 11:57 AM
Originally Posted by 2.3 Evo 8
Need more info!
What kind of tires? Stock advans
Tire pressure? Completly filled. I had no tire pressure gauge to adjust it
Suspension?k sports. Don't know the the model off the top of my head. They are the step down from the model that has the black strutt bodys
trying to slip it like the stock clutch. Ie. Preload the driveline and slip it off the line. The launch was at 5800
Old Jul 12, 2008 | 12:01 PM
I have been looking at doing all the motor mounts soon. Any sugestions? I want to do all three and have been looking @ AMS's set.
Old Jul 12, 2008 | 12:38 PM
Liqquid's Avatar
I did the 3 powerflex ones first, they worked good... recently I put in the Buschur rear mount, and there was a big improvement in drivability with the Exedy stage 2 clutch I had. More vibration, but worth it for sure... now, I noticed that they (Buschur)recommend doing the front and rear only... I'm wondering how much less vibration it would be with just the front and rear.
Old Jul 12, 2008 | 02:08 PM
i dont really care about the vibration cause the end state of the goal is to be a drag only car...thanks for the good info thou
Old Jul 12, 2008 | 06:10 PM
Liqquid's Avatar
Don't F around then get the replacement lower brace with solid mount, rear poly mount, and those rear diff ear replacements... she'll stop moving around then!
When mine sits in the garage or rolls into the track on a trailer, I'll be doing the same
Old Jul 13, 2008 | 02:31 AM
i plan to but i gotta drive across the US soon so i gotta wait on all purchases
Old Jul 13, 2008 | 05:40 AM
mtevoracer's Avatar
I was having a similar problem, and it depends on the turbo size. 5800 is good for a stock turbo but judging by your et you probably got a 35r. I got a 35r and I started my two-step this year at 5800 and the best I could do 1.89 60'. So I raised it to 6350 and ran 23 psi on RE-O1R's. and ran a preaty consisant 1.70 60' with best 1.61.
Old Jul 13, 2008 | 09:18 AM
i wish i had a 35r or bigger, im still on the stocker. i just wanna find out this problem before i upgrade the turbo. no sense in getting a bigger turbo if i cant launch it right. the only reason i think its my clutch is that i was doing great on the stocker, started to go out and i shipped to iraq for a bit and put it in while i was gone. so the whole launch idea is new on that..but im willing to take sugestions on other things to help the launch
Old Jul 13, 2008 | 02:12 PM
is 116 a high et for the stock turbo?
Old Jul 13, 2008 | 11:05 PM
bump
EvoDan2004
73
Oct 19, 2009 11:45 AM
evovin
42
May 22, 2008 01:39 PM
TTP Engineering
Sep 5, 2007 05:55 AM
s10v8
Jun 19, 2007 05:04 PM
Agent-Smith
Oct 19, 2006 11:59 AM
