First time at the track!
Old Jul 19, 2008 | 01:37 PM
EVOIXreno's Avatar
I cant load my slip so I will read it off
My Fastest Time
I1: 1.89
I2: 5.395
I3: 8.329
MPH at I3: 84.761
I4: 10.88
E.T 13.025
MPH 105.577
Next Fastest
I1:1.894
I2:5.4
I3:8.343
MPH at I3: 84.529
I4:10.9
ET 13.041
MPH 105.865
I was hoping for 12's I am tuned at 23 psi on 91 oct. What can I do better..I know I need to get my 60ft down...I was spinning quiet a bit outta the hole.
TIA Cory
Old Jul 19, 2008 | 01:39 PM
JakeTheVIII's Avatar
Less spin for one.....make sure you stay outa the water and get some better tires or something
Old Jul 19, 2008 | 02:20 PM
Warrtalon's Avatar
Remember that Reno is at pretty high altitude, so you're going to be slow relative to the rest of the country except those of us in Colorado and Utah.
That being said, it's all 60'. Your launches were very weak, and that's the only thing that kept you out of the 12s. Otherwise, the shifting seems pretty good.
You should not be spinning with such low power, so you must have had your tire pressure up really high. When you're spinning, just lower the tire pressure until it stops but no lower than low/mid 20s.
Old Jul 19, 2008 | 02:26 PM
Gavin@TopLevelPerformance's Avatar
Pm wiznaz he got a video that can help you out???.
EVOIXreno's Avatar
I know the launched sucked!!! Tire pressure were at 40 psi I lowered them to 33ish... I will work on the launch and get into the 12's easily then.
Edit: Forgot to mention it was 90*F when I was racing!
Old Jul 19, 2008 | 04:21 PM
4bangn's Avatar
40 psi??? stock tire pressure is 32 up front and 29 in the rear, try lowering the pressure to around 28 or 27 all around when ur dragging
Old Jul 19, 2008 | 04:27 PM
eponti's Avatar
That's not bad for your first time out there.
Old Jul 19, 2008 | 04:41 PM
EVOIXreno's Avatar
Thanks man...I wanna beat you though... 12.5's here I come!!!
Old Jul 19, 2008 | 05:25 PM
eponti's Avatar
You can beat me now pretty easy.My clutch went out last night after hitting my 12.5.It is toast.If you can bring your 60 foot down your in the 12's easy.We should have just lowered your 2 step last.
Old Jul 19, 2008 | 05:46 PM
EVOIXreno's Avatar
LOL that sucks.... Yea we should of... I wasn't hitting my boost either.. usually 20-21 psi tops.... I turned it up but no big difference!!!
Old Jul 19, 2008 | 05:51 PM
Warrtalon's Avatar
YOu never hit peak boost on the drag strip, because you're never at low enough RPMs. People ALWAYS get fooled by this.
Old Jul 19, 2008 | 10:25 PM
eponti's Avatar
^+1
Old Jul 19, 2008 | 10:27 PM
eponti's Avatar
I wont be hitting the drags any time soon.Have to save some money for a clutch.
Old Jul 20, 2008 | 04:54 PM
EVOIXreno's Avatar
So warr...with the temp being in the mid 90's do you think my time would have gone down at all if the temps were in the 70's?
Old Jul 20, 2008 | 04:55 PM
Warrtalon's Avatar
Yes. Could be .2s/2mph maybe.
That's also why I'm excited, since my 11.51 was on an evening when it was 97* upon arrival and probably hovering around 90* still when I hit a slew of 11.5s. That's why I'm holding out hope I can do an 11.49 or better when our short summer ends in September.
