11.7 @ 113..
Old Aug 31, 2008 | 02:58 PM
andreww238's Avatar
11.7 @ 113..
hey guys.. went out to the track for the really first time with the car... had a 1.7 60ft on street tires... i was wondering why my trap seems so low? i def. can admit i need to practice more with the car..
Old Aug 31, 2008 | 03:01 PM
06MREvo's Avatar
Your trap should definitely be higher then that with a 35R. Did you log any of your runs by chance, or no? Boost leak? I trapped that with stock turbo and only ran a 12.3.
Old Aug 31, 2008 | 03:12 PM
06MREvo's Avatar
Did you let off before you crossed the 1/4? Post the rest of your time slip...probably help some other people figure out why your trap is so low...
Old Aug 31, 2008 | 03:16 PM
Mellon Racing's Avatar
that mph is awfully low for that e.t and you didn't have a extremely low 60' I think you let off too early.
Old Aug 31, 2008 | 05:24 PM
k2boarder3187's Avatar
just like you said you need more practice....i def think you let off
Old Aug 31, 2008 | 06:51 PM
andreww238's Avatar
ill try and find my slip... i dont think i let off...i boost leak tested like a week or so ago and it was good...i'll have to check again.
Old Aug 31, 2008 | 06:59 PM
post the rest of the slip numbers and maybe it'll make sense. You should be picking up about 30mph from the 1/8th to the 1/4
Old Sep 1, 2008 | 09:24 AM
Nvr2old32's Avatar
My guess, your alky kit was not firing. About a month ago, I made two passes and was only trapping about 113/114. I couldn't figure out why I was trapping 8mph slower. I started pressing the test button on the alky kit and it wasn't spraying. So, I'm going under the assumption (without having logged the runs) the AEM was pulling all the timing up top to keep the engine from blowing. Just my guess but I'd check your alky.
Old Sep 1, 2008 | 10:22 AM
evovin's Avatar
post the time slip
Old Sep 2, 2008 | 11:35 PM
Sean@Iveytune's Avatar
That trap is very low for the HP you make. Something is up.
What is the boost set at? What is your AF going down the track?
Are you going into 5th?
Sean
Old Sep 2, 2008 | 11:36 PM
evo@24psi's Avatar
Trap Speed is WAY low!!!
Old Sep 3, 2008 | 09:23 PM
staatz's Avatar
Weren't you shifting at like 7k though too Andrew? Atleast you faired out well that night..lol
